504 diff plugs tool
Results 1 to 16 of 16
Like Tree5Likes
  • 3 Post By TassieExec
  • 2 Post By Demannu
Thread: 504 diff plugs tool
    ccc
    ccc is offline
    Member ccc's Avatar
    Dec 2014
    brisbane
    114
    Default 504 diff plugs tool
    Hi
    Am after the correct shape plug socket to remove both the inspection & drain hole plugs on the 1973 504 differential.
    Its not a square drive.Its almost a 4 leaf clover shape...
    Not keen on trying to make one.
    Anyone have a spare one or know of a supplier?
    thanks
    SWOTR
    3,632
    I've only ever seen square drive fill and drain plugs on 504 diffs. Maybe it's not the original one?
    Dec 2004
    Devonport Tas.
    354
    The plugs in question may be square drive plugs that have been butchered through the use of the incorrect tool, as that can create something that looks what was described in the original post
    Regards
    Neil
    2pac, addo and Wildebeest like this.
    Dec 2002
    Menzies Creek
    2,541
    Step 1: Buy new plugs and the correct tool.
    Step 2: Chisel old plugs out.
    Step 3: Profit.
    addo and jo proffi like this.
    Scotty
    Melbourne - Dandenong Ranges
    2014 Peugeot RCZ - 'Remy'
    Perth Western Australia
    2,694
    Step 1,5
    Strike the face of the plug. This will flatten the copper sealing washer/s making them easier to remove.
    Dec 2002
    Menzies Creek
    2,541
    Good thinking 99!
    Scotty
    Slovenia
    198
    Should be an 8mm square I think.
    1000+ Posts Beano's Avatar
    3,147
    Peter Chisholm and TassieExec are correct.
    Just grind down the end of an allen key into a square shape. When you're then using it, you can use a socket on the other end.
    Step 1,5
    You'll only have to do this if it's stuck, which is rare. It is in fact the recommended method, but be careful. My local pug repairer did this years ago while I was watching, and cracked the diff housing. There were 2 normal sounding hits, then the third hit gave a dull sound, and we both knew immediately what had happened. Had to fit my secondhand diff.
    Better to use a hammer that is not too heavy.
    Fellow Frogger! sfrawley's Avatar
    Feb 2001
    Goolwa SA
    339
    These tools were on supermarket shelves in France! I should have brought a few back but our bags were full of fridge magnets.
    Stephen
    '03 P406 HDI
    '16 Renault Master
    SWOTR
    3,632
    I've never had to resort to hitting the plug. I know others have successfully done it this way but I've always been fearful of cracking the diff housing. Once or twice I've got out a small cold chisel on the edge of the plug and tapped it loose. You end up with a dodgy looking plug though.
    You used to be able to buy square drive sockets off the shelf around the traps and it may pay to check.
    Fellow Frogger! Pug72's Avatar
    Feb 2013
    310
    I purchased my 8mm square drive through Snapon tools
    Fellow Frogger! julian b's Avatar
    Aug 2011
    hawthorn melbourne
    482
    The original plugs would have had square holes .If yours resemble clover leaves someone has probably changed the plugs and sockets should be available to fit from Total Tools or Repco . I have had 504s that have the plugs changed to protruding square drives that are easy to find tools for.
    2,694
    Geez! What sort of hammers were you using to strike the plug. Club hammers?
    I should have added, Strike the face of the plug using a soft faced, copper head hammer.
    ccc
    ccc is offline
    Member ccc's Avatar
    Dec 2014
    brisbane
    114
    Hi all
    Have just used a home made 8mm sump plug male drive to remove the inspection plug in the diff & top up the diff..
    It was made from an old 18mm zenith galvanised bolt.
    The bolts shaft diameter was 11.9mm.
    The square profile is 7mm long (ended up a 7.7 *7.7mm square) was hand filed into the unthreaded part of the bolt.
    The length of the bolt ended up only 23mm.
    About a 1/2 hour job needing a good vice, file & a vernier guage.
    Curiously the remover wont fit the drain plug (tool large), so will make another.
    cheers
    SWOTR
    3,632
    Well done and a cheap solution!
    3,147
    The Pug mechanic in question had meaty forearms and a bit of a temper
