2007 207 GTi Fault Code P2191 and P0171
  • 1 Post By SLC206
Thread: 2007 207 GTi Fault Code P2191 and P0171
    Jan 2015
    ACT
    62
    Default 2007 207 GTi Fault Code P2191 and P0171
    Hi Guys,
    Has anyone encountered these fault codes P2191 and P0171? From the reading i've done it appears to be related to a 'depollution fault'. Some of the fixes tried includes replacing the lambda sensor to the timing chain/tensioner, sprockets etc.
    I bought the car second hand and it has only done 50,000Ks. It hasn't had the timing chain/tensioner replaced before and I understand a common problem with the THP engines has been stretching of the chain.
    Has anyone had this problem and resolved it, if so how and at what cost?
    Thanks.
    Fellow Frogger! Dijon16's Avatar
    Jan 2005
    378
    Had to find the codes myself recently, different ones from that but for the same model, came up with about 20 links.
    I printed them out, those particular ones look to be "mixture regulation fault", but I cannot find the link that had them listed, so the line spacing may be a little bit out on the printout and they could be for the fault above or below.
    You really can't do much until you get them verified, other than spend hours searching on the interweb like I did.
    Sep 2003
    North Parramatta
    3,997
    Yes, they are both "Mixture regulation fault: mixture too lean".
    Got this from somewhere or other: THP specific fault codes.pdf
    addo likes this.
    Simon
    2018 308 GTi 2011 DS3 DSport
    www.peugeotclub.asn.au
    Don't remind me!
    16,609
    An example of where the machine stops and the brain starts. Vacuum leak? Cam phasing? Fuel pressure? Sensor fault?
    The next step is to look at live parameters to see whether everything appears to be within spec.
