Best safest way to remove airbag from steering wheel
Results 1 to 15 of 15
  • 1 Post By Fordman
Thread: Best safest way to remove airbag from steering wheel
    Nov 2014
    Melbourne/Victoria/Australia
    138
    Default Best safest way to remove airbag from steering wheel
    Gday All,
    I've got 307 and I need to swap over the steering wheel as this current one is peeling and I'm getting it repaired and in mean time I have a loan one from another 307.
    what is the safest way to remove and disconnect the airbag from it?
    i know how to remove the hornpad - do I need to disconnect the battery?
    AP
    7,487
    Yes, I think disconnect battery and wait 10mins before removing.
    9,028
    Emphasis on "wait". You must be certain that the airbag controller is well and truly unenergised.
    Oct 2005
    Rome
    2,660
    Disconnect the battery and wait for 30 mins. That's what is recommended if you are fooling around under the seat for the side airbags so I guess that's a safe rule of thumb.
    Dave
    ​1997 BMW K1200RS
    IR655
    8,431
    Quote Originally Posted by 68 404 View Post
    Dave
    Even safer still.....
    Do the battery/30 min thing, then get the person who you have organised to remove the airbag to start removing it.
    A bit like when working on roofs or ladders...Someone apart from the person doing all the work needs to standby and fulfil the very important role of calling the ambulance in an emergency.
    Jo
    1000+ Posts FIVEDOOR's Avatar
    Jun 2011
    Brisbane Qld
    20,604
    Reminder of what can happen if one lacks respect for airbag, or is too drunk
    https://www.youtube.com/watch?v=rioPxrj1DG4
    Every day is a good day
    Don't remind me!
    16,609
    Care and common sense apply, it is VERY hard to trigger an airbag though. Work reaching in from the side, with your head out the car.
    Have not hard of one going off unplanned here in a workshop environment.
    1000+ Posts Peter C's Avatar
    SWOTR
    3,656
    Jo
    This is the same approach employed when testing an electrical appliance you've just "fixed".
    1000+ Posts Fordman's Avatar
    May 2004
    Perth/West Australia
    1,443
    To feel safer when changing steering wheel:
    As above, disconnect battery for recommended time to de-energise the electronics. Seems a fairly standard procedure in many makes of vehicles.
    Then airbag assembly can usually be simply removed from wheel with couple of screws, and harness plug disconnected just behind assembly. Carry assembly to other side of workshop (don't drop it) and carefully place it on the floor with the airbag facing UP. (Just in case it goes off, it then won't put the metal backing of the assembly through the roof, or kill someone!). Recommended procedure.
    You then feel a lot safer working on the wheel, or instrument panel.
    JohnW likes this.
    2004 Scenic I 2.0 auto (Hers)
    2016 Ford Territory (His)
    2004 WRX (Sunday car)
    Nov 2014
    138
    Thank you for your replies guys...
    Is there a specific procedure after I restore (re-connect the battery) or just do it normal ie. start the car and let the computer re-learn everything?
    AP
    Nov 2014
    138
    Jobs done - I was impatient (since I had a spare airbag) I changed it over after 15mins disconnecting the battery. Now I have 307cc steering wheel, much better than 307 standard which was peeling bad.
    Thanks once again.
    AP
    Aug 2012
    Penrith, NSW
    113
    Good work. Too late for me to reply, but when I removed mine, I also disconnected the airbag computer which is found under the cupholder in the centre console - as advised by the Haynes manual. As you now know, the process is ridiculously easy. Insert a screwdriver into the hole on the side, pop it out, repeat on the other side and bob's your auntie!
    Unfortunately for me, my airbag light is still lit with a "low resistance - Driver's airbag" message from the ECU. I believe I am up for a new clockspring to resolve this one.
    Any assistance with the clockspring replacement (and the source of a good replacement) would be awesome.
    Nov 2014
    138
    Quote Originally Posted by borosa View Post
    What is clockspring?
    AP
    Don't remind me!
    16,609
    It's the bit he broke.
    No, it forms an inseparable part of the COMMS hub. Prior to removal you must center the wheels, then after careful extraction of the steering wheel you make sure the small indexing marks align on the clockspring inner and outer. It's possible to put them in a whole turn wrong - which doesn't help their service life.
    Aug 2012
    Penrith, NSW
    113
    Thanks Addo... Yeah, not a job for the faint of heart, or something to attempt in under 3 hours! Pretty critical part so I want to get it repaired sooner rather than later despite it not stopping me from using the car.
