Mi16 "Running Hot" issue
Results 1 to 17 of 17
  • 1 Post By PeterT
Thread: Mi16 "Running Hot" issue
    Member renard argente's Avatar
    Mar 2012
    Ourimbah, Australia
    64
    Default Mi16 "Running Hot" issue
    Mes amis,
    So, my 1.9 Series 1 started to run quite hot & cabin smelt of anti freeze. Checked for leaks around radiator & associated pipes + (gulp) under the heater. Phew, no heater leaks or signs of leaks in engine. Hmm.
    Off to favourite mechanic for a pressure test which showed small holes in lower corners of radiator + 1 of the heater hose's ends were crazed. Of course, like many Euros, you can't buy replacement elbows etc to fix the problem but keeping the functioning radiator.
    So, new radiator fitted by favourite mechanic along with new anti freeze who suggested to keep an eye on level of fluid & top-up if need be.
    Hmm. Forgot to ask him to flush the system, so I drained it - with heater on - filled with clean water then ran radiator flush for 30 minutes. Before refilling with anti freeze, take test run. Water temperature gauge now showing MAX temperature: i.e. beginning to boil!! Fans running furiously. Tried a couple of more runs with same result. !!!!
    No point in taking back to favourite mechanic who'd only take it to the well-known radiator/cooling/air-con company, so, leaving home pre-traffic & very gingerly with bonnet propped open but strapped down, off to aforementioned radiator / cooling system outfit.
    1 air lock + a reverse flush + new anti freeze + a new thermostat to replace the 1 that had "lost" (!!) its triangular shaped brass "bit" in which the centre rod is supposed to be housed + a suggestion that it might run a bit hotter, later, off home I went.
    Now, prior to whole this episode, the Mi ran at about 70 - 75/80 degrees, climbing to 90-ish on really hot days. It now runs 85 - 90, climbing quickly to high 90s - 100+ in traffic during the recent hot & humid conditions
    Any suggestions please as to what might be causing this concerning rise in operating temps, especially in traffic? Pardon my ignorance, but don't thermostats come in temperature ranges according to the marque's specs? Maybe the radiator / cooling system outfit have fitted an incorrect part.
    Your assistance would be greatly appreciated.
    Merci
    1000+ Posts pgti6's Avatar
    May 2001
    1,635
    Did favourite mechanic bleed the cooling system to purge out the air?
    Lap times-
    Sandown 1 27.9
    Phillip Island 1 53.8
    Previous Frenchies-
    1988 205Gti
    1998 306 GTi6
    1997 306 N5 sedan
    1996 306 N3 XT hatch
    Mar 2012
    Ourimbah, Australia
    64
    Quote Originally Posted by pgti6 View Post
    Don't know as I didn't & haven't asked him, but, I witnessed the "specialist" cooling system chap do it.
    May 2012
    Australia
    185
    Perhaps you previously had a 82 degree thermostat fitted and now have an 89.
    Don't remind me!
    16,609
    You have a blown headgasket, probably from either the gasket corroding away or corrosion to the head's sealing face itself.
    For the short term, bypass the heater and try some "silver seal" or similar. Start ordering in the parts to fix it properly.
    Jul 2004
    803
    I wouldn't bag the headgasket just yet. Mi's can be a pain to bleed and can take 2-3 go's over 2-3 days before temp settles back to normal. 88lp also makes a fair point that a later opening temp thermostat was fitted, although if you have the original thermostat housing with no adapter plate only 1 thermostat fits.
    2006 Peugeot 206 Xt
    1991 Toyota mx83 grande 1jzgte
    7,513
    If you completely open the two bleed screws and fill with coolant, the majority of any air will be removed, as the two screws are the highest points in the system. Fit the screws, start it, warm it up and wait for the coolant to stream via the bleed holes and usually the job is done.
    Jan 2015
    New Zealand
    32
    In my experience using a header tank greatly helps the bleeding process, but even so a couple of goes are often a good idea to make sure all air is removed- if not an 'air lock' could produce symptoms you've described. Bleed again should be your next move.
    A poor seal of the radiator cap is a common cause too, a simple problem easily fixed but you have to think to look. If you're still using the old radiator cap I'd suggest replacing it, or if new try the old one again.
    7,513
    The Mi16 has a header tank.
    Jan 2015
    New Zealand
    32
    Thanks, couldn't remember if it did or not.
    7,513
    Most people don't realise the side of the radiator is a header tank.
    addo likes this.
    Mar 2012
    Ourimbah, Australia
    64
    Thanks PeterT, but I - & possibly both mechanics - only found a bleed valve on top of the thermostat housing. Where is the other please?
    Mar 2012
    Ourimbah, Australia
    64
    Quote Originally Posted by Pee Dubs View Post
    Thanks Pee Dubs. The old radiator cap has been re-used & is rather difficult to get off & back on, so will get a new one just in case.
    Will re-bleed when PeterT advises where the 2nd bleed valve is.
    In the meantime, THANKS to everyone for your input, even if talk of a blown head gasket caused palpatations
    Don't remind me!
    16,609
    The bleeders are above your thermostat housing, and at the back of the head where a transfer tube runs left to right. There's also the radiator left side tank top bleed screw.
    And I still think your head gasket is going.
    Mar 2012
    Ourimbah, Australia
    64
    An update:
    Bled the cooling system from the screw / valve on top of the thermostat housing. No bleed screw on new radiator's header tank & too much plumbing at bulkhead side of engine to locate the transfer tube's screw.
    Never the less, an interesting exercise. Splurted as to be expected with some gaps with no fluid run-off. Then remembered to open the heater. Quite a delay before the jolly green fluid began to splurt again. Ran for a while till fluid started running reasonably constant.
    Will now monitor temperature over the next couple of days &, subject to that, will bleed some more if needed.
    No offence addo, but, in this instance & as you'll appreciate, I HOPE that you're wrong re a blown head gasket.
    Merci buckets mes amis for your help.
    Don't remind me!
    16,609
    The heater is in constant loop, turning the heat off or on has no bearing on water flow through it.
    I'll photograph the bleed points otherwise described - wondering if you were not given quite the correct radiator.
    No offence taken either; it's usually something I have in surfeit and give generously to others. My PRV has settled at an "equilibrium" state for the time being with its BHG; still too hot but an underfilled expansion tank is meaning it no longer purges half a litre of coolant each day. That was getting expensive.
    1000+ Posts lion5's Avatar
    Jan 2013
    1,675
    from haynes:
    other bleed screws on those radiators look different but are usually located at hte top somewhere.. i saw another saxo VTS thread with the bleed screw not in the exact same position, but very lose to there
