Anyone had a oil leak from a 308 HDi ? - Page 2
Page 2 of 2 First 12
Results 26 to 30 of 30
Thread: Anyone had a oil leak from a 308 HDi ?
  1. #26
    Feb 2011
    New Zealand !
    173
    Quote Originally Posted by AlpineRaven View Post
    What kind of rear seal additive was it?
    AP
    This one
  2. #27
    Feb 2011
    New Zealand !
    173
    All - another update
    I finally had a dealership diagnose and resolve the oil leak
    The dealership I took the vehicle too [b] afer ruling out any issues with egr, intake manifold congestion, pressure valves etc removed the gear box and found that the rear main seal was not installed correctly i.e. in as far as expected. Furthermore they could see 'scuff' on the bearing the seal goes over which would have compounded the issue that should not be there.
    I have gone back to dealership [a] who installed the seal in 2011
    Question: Can a real main seal ever come loose ?
    AP
    Rislone Rear Main Seal Repair - it didn't work
  3. #28
    Mar 2017
    Perth
    17
    is it same issue on 508 2.0 hdi ? Engine or only gerabox out? Anything else to do ?
  4. #29
    Fellow Frogger! Mi16 Man's Avatar
    Canberra, ACT
    709
    Quote Originally Posted by tristoosam View Post
    If the rear main seal, yes, gearbox out. I had my transmission replaced under warranty so I paid for a new rear main seal to be replaced at the same time. Made sense.....
    Im chasing a slight leak at the moment and its mainly coming from the top hose on the intercooler. They are wet on the inside.
    "Take a Lion through a corner - FAST"
    Current Fleet;
    2010 308 XSE HDi SW [Vapour Grey]
    2010 VW GOLF GTI [Carbon Steel Grey]
    In the Family;
    2012 508 Allure HDi [Thorium Grey]
    2008 207 HDi XT [Bianca White]
    Past "Frogs"
    2008 308 XSE HDi SW / 2006 307 XSE HDi Touring / 2001 306 XSi / 2005 206 GTi180 / 2005 407 HDi / 2003 206 XT / 1993 SII 405 Mi16 / 1990 205 GTi / 2x 1985 505 GTi S1 / 1976 504 / 1982 20 TS / 1997 306 XR / 1992 205 Si
  5. #30
    Tadpole 207ccRipper's Avatar
    Aug 2018
    Victoria
    12
    308 tend to leak from the rocker cover gasket and the sump gasket also the vacuum pump to head seal. Give it a good wash and look closely as to where the leaks come from
