BA10/5 noise in neutral
Results 1 to 3 of 3
    Fellow Frogger! julian b's Avatar
    Aug 2011
    hawthorn melbourne
    482
    Default BA10/5 noise in neutral
    Is it normal for this box to whine in neutral? .It is quiet in all the gears .I once had a 504 wagon that was almost new that I bought damaged that had the same whine .
    8,939
    Doesn't sound right to me. Here's the manual http://www.505turbo.com/august/techn...verhauling.pdf
    PS There's an article about whines by Bill McNamee in the Pugilist, May 2011 (You can probably find it online).
    Blue Mountains, NSW
    433
    Not normal, but probably not much to worry about. It might be the small bearing where the input shaft mates with the main shaft. This will not be turning at all in 4th gear and will be turning at various rates in the indirect gears. In neutral, the speed difference between the input shaft and main shaft is maximised, and it might be that this bearing, though unloaded, is making a fuss about it.
    Well, that's my stab, for what it's worth.
    Have fun,
    Rob.
