205 (SI) Lower Control Arm Issue
Results 1 to 2 of 2
    Hobart
    1,496
    Default 205 (SI) Lower Control Arm Issue
    Gday All,
    I've just been changing a hub on a 205 SI here to deal with a rumbling wheel bearing, now the issue I am having is putting the lower control arm back into place.
    It seems impossible to line up the ball joint, swaybar and subframe and get it all together, I've tried doing it several different ways (including swearing) and just cant get it.
    It's frustrating as I've done them in the past (some time ago) and don't remember having this issue.
    Any advice would be greatly appreciated.
    Ben
    1989 Peugeot 405 Mi16
    2000 Peugeot 306 XSI
    1973 Peugeot 504 GL
    Far North Queensland
    1,494
    Do you have both front wheels off the ground?
    If not the pressure on the sway bar from the grounded wheel can push the sway bar up and make alignment difficult.
    Paul
