XUD11BTE Diesel 2.1 TD 12V Engine
    Jan 2014
    Coffs Harbour, NSW Australia
    330
    Default XUD11BTE Diesel 2.1 TD 12V Engine
    Mornin, HELP!! Hoping someone can give me very good clues as to where to find the hole for inserting the rod/timing tool to accurately determine top dead centre for #1 cylinder in the 2.1 12v engine
    Any assistance much appreciated.
    Dec 2002
    Menzies Creek
    2,541
    Scotty
    Melbourne - Dandenong Ranges
    2014 Peugeot RCZ - 'Remy'
    1000+ Posts pgti6's Avatar
    May 2001
    1,618
    This is for an XUD9 but might help since the locating tool is the same shape as XUD11.
    http://www.citroenkerho.fi/xantia/pd...iikka/XUD9.pdf
    page 25
    Lap times-
    Sandown 1 27.9
    Phillip Island 1 53.8
    Previous Frenchies-
    1988 205Gti
    1998 306 GTi6
    1997 306 N5 sedan
    1996 306 N3 XT hatch
    Dec 2002
    Menzies Creek
    2,541
    This is probably a better view. The original PSA tool makes it 'less difficult' to do without removing the starter motor first.
    Scotty
    Jan 2014
    330
    Thanks heaps Demannu and pgt16. With the knowledge rather than guess work it was possible to correctly time it and do compression tests prior to replacing water pump, tensioner pulley and getting it into service. Any clues as to removing what is likely to be the original cam belt tensioner.?? Bought the car as a non-goer with 390k on the odo and the last belt change at 330k. Lifting the rocker box revealed 4 broken exhaust rockers and nothing else apparent. Removal of cam belt covers showed an intact belt, an idler that was now in 2 pieces and a crank pulley that was well past its use by date, - the work had been done by a Peug 'specialist' and quite why such aged parts were left in situ is beyond me.
    Anyway the hope was that 12 new rockers and new belts etc would see the old girl good for a few more years but such is not the case; #1 read 435 psi , #2 375 , #3 030 and #4 is untested as it's a bitch to access and doesn't matter as its now head removal time unless the #3 intake valve/s leak is due to a clearance problem resulting from the use of new rockers all round.
