505 sti knocking/ticking
Results 1 to 12 of 12
  • 1 Post By Pavel Moore
Thread: 505 sti knocking/ticking
    Oct 2014
    hobart tasmania
    6
    Default 505 sti knocking/ticking
    Hi guys. Im new to this forum and Im from tassie.
    Just recently purchased a 505 sti for $300, which i thought was a win!
    It has a knocking sound upon acceleration, on idle it sounds completely fine! My thought was it could possibly be a manifold leak? Im quite new to working on engines but im really keen to get this thing running nicely! Any input would be much appreciated. Thanks guys!
    Fellow Frogger! julian b's Avatar
    Aug 2011
    hawthorn melbourne
    482
    Could be piston slap .A manifold leak would be evident at idle too
    Oct 2014
    hobart tasmania
    6
    It does have a distict slapping sound. You can only hear it towards the rear of the motor if that any concelation
    Mar 2011
    Kendenup WA
    124
    Suggest you check your ignition timing.
    If the ignition was set up [advanced] to take advantage of anti-knock 95 or 98 octane, and you use 91, it will knock.
    Pavel
    Wildebeest likes this.
    Oct 2014
    hobart tasmania
    6
    No worries. I'll check iy out!
    Aug 2011
    hawthorn melbourne
    482
    Incorrect timing would cause a fast pinging sound .This could also be caused by fuel that has been in the tank for a very long time and has gone off.
    Oct 2014
    hobart tasmania
    6
    Its quite a loud knocking/slapping. Not your usual pinging sound. But it would definitely have old fuel in it, and it also sounds a bit like a boxer engine. I've got a thermo time switch on its way from LA at the moment to fix a cold start issue.
    Last edited by tassiepugga; 19th October 2014 at 10:57 AM. Reason: forgot something
    Oct 2014
    hobart tasmania
    6
    505 sti running rough: 505 sti running rough - YouTube
    This is my car.
    1000+ Posts Mike Tippett's Avatar
    Jan 2002
    Vancouver Island, Canada
    1,743
    That is running only on 3 of the 4 cylinders
    1966 Peugeot 404 Coupé Injection post-restoration reassembly underway!
    Register your 404: https://recensement.leclub404.com/submit.php
    8,420
    With an ir temp gun aimed at the zorst manifold, it is not hard to work out which cyl had a misfire ( if that is the issue)
    Jo
    Hobart
    1,494
    The problem with the cold start on that car is the cold start injector. Easy fixed, I've got one if you need it.
    It's defiantly running on 3, that car has had a recent history of electrical problems in the dissy and ignition area so thats worth checking. Again happy to help if need be, I've fixed my fair share of them.
    I was going to get that car, but really didn't need another one in my life
    Ben
    1989 Peugeot 405 Mi16
    2000 Peugeot 306 XSI
    1973 Peugeot 504 GL
    Oct 2014
    hobart tasmania
    6
    Quote Originally Posted by Pug_405_Mi16 View Post
    Ben
    Rightio so I've replaced all of the spark plugs and bang. We have 4 cylinders...
    One of the plugs wasnt firing what so ever. Seems to be starting completely fine now also. Very happy chappy!
