406 Catalitic Converter
    Jun 2012
    Port Macquarie
    56
    Default 406 Catalitic Converter
    Can anyone tell me what is wrong with my Catalitic Converter as it is progressively getting noisier, as if there is a hole in the system.
    When I block the exhaust pipe there is good strong pressure and I can hear/find no leaks.
    The converter was renewed 5 years ago.
    When the engine has warmed to about 55/60 degrees the noise nearly disappears but when I accelerate it sounds like a hot-rod.
    Any help someone!!
    Dec 2012
    187
    Are you sure your cat is still in one piece?
    My 306 had a completely shattered cat for ages and a real nice growl from 2000 rpm to 2500 rpm. Different exhaust length on a 406 might cause different resonance.
    Then i got it fixed and it was dead quiet. Almost wish i hadn't fixed it after!
    Jun 2012
    Port Macquarie
    56
    Thanks, what did they fix, any idea??
    I got under the car and had my wife start the car from cold (when it is the noisiest) I checked for leaks , none, but when I grabbed the Cat to move around under the car the noise diminished slightly and I could feel it vibrating.
    Check the last time it was replaced; 2010, 4 years.
    Guess I'll have to take it to the Exhaust shop.
    Dec 2012
    187
    To be honest I'm not sure if the section with cat in it was replaced or cut and welded back up with new cat element inside.
    To diagnose the broken cat I tapped it with a screwdriver and could hear fragments moving around.
    Mar 2011
    413
    Picture a bunch of rocks rattling around in a vibrating tin can. That's what my cat sounded like when it started to fail, and was worse when the car was cold. The other symptom I had was a thin white 'smoke' from the exhaust when the engine was under load, which I only noticed by chance. Wasn't actually smoke but ceramic dust being blown out of the cat down through the exhaust.
    2000 306 GTi6 'Josie'
