205 dim headlight
Results 1 to 8 of 8
    Aug 2014
    22
    Default 205 dim headlight
    Never seen this in a car before - the passenger side headlight lights up on dipped beam, but is dim compared to the driver's side. But the kicker is that when I click on main beams, the passenger side goes dimmer.. WTF?! Anyone has this problem before? Thanks.
    Fellow Frogger! julian b's Avatar
    Aug 2011
    hawthorn melbourne
    482
    Try swapping globes between L and R and if the dim light swaps sides then the globe is the problem.
    Aug 2014
    22
    I tried a new globe in the dodgy side instead, and it was the same dimness. Bummer. I'm guessing it might be an electrician job.
    Don't remind me!
    16,609
    You could first check the "tension" of each connector in the plug on back of the bulbs, excessive heat makes them lose their springiness. Then beef up the ground wires. A final step is separate relays to provide a more direct voltage to each bulb. Keep it tidy and discreet, only the most picky will notice the change.
    San Diego, California, USA
    3,543
    Check the lamp grounds. Current is looking for the shortest path to ground, and on occasion that is through the filaments in the bulbs.
    Aug 2014
    22
    Cool thanks. I had a meter on it last night and its only getting 7 volts..
    Don't remind me!
    16,609
    Between the two bulb terminals, or from the bulb positive to chassis?
    Aug 2014
    22
    Bulb positive to chassis. Had it sorted out now. Was a bad earth. Cheers
