Seat Belt Alert
Results 1 to 23 of 23
Like Tree4Likes
  • 1 Post By DoubleChevron
  • 1 Post By Peter Chisholm
  • 1 Post By addo
Thread: Seat Belt Alert
    Sep 2014
    north parramatta
    91
    Default Seat Belt Alert
    I appreciate Peugeot's concern in keeping me safe and ensuring I always have a full battery. Thanks.
    However there are these occasions when I don't wear a seat belt:
    - I am moving the car from the street to my garage
    - I am moving the car up a few spaces
    - I am reversing
    The seat belt alert in these situations drives me nuts. Is there a way to disable this?
    I have driven cars for over 20 years and never ever forgotten to wear seat belts so please I dont need the car to tell me what to do.
    1000+ Posts FIVEDOOR's Avatar
    Jun 2011
    Brisbane Qld
    20,554
    Quote Originally Posted by french-car-newb View Post
    It's the substitute wife
    Every day is a good day
    1000+ Posts Kim Luck's Avatar
    Melbourne, Aus.
    18,087
    If you are on a public road you must wear your seatbelt whilst driving a vehicle.
    Ditto above
    - I am reversing
    I believe it may be acceptable to remove your seatbelt when reversing. However, the gallic twit that programmed your seatbelt warning forgot to disable the warning when reverse gear is selected.
    Two of the three situations you have described indicate that you may need to be told when you need to wear a seatbelt......
    Lawstuff Australia - Know Your Rights - - Topics - Cars and Driving - Road rules
    Sep 2014
    north parramatta
    91
    Wow now I have a lawyer sitting next to me. eeeeeeeeeeeeeeeeek
    Banned
    sydney, australia
    11,301
    i imagine you will get a sensible and correct answer in due course, but just in case....
    i would think there is a pressure switch under/in the seat which is closed by the application of your bum, so i would be looking under the seat for the wires connected thereto, with a view to permanently disconnecting them. unless of course peugeot has come up with some complicated higher tech electronic solution to this simple function. which is possible.
    cheers
    alexander
    Feb 2001
    Romsey, Victoria, Australia
    4,869
    There must be some way to deactivate it otherwise it's going to drive the people in the trade absolutely mental.
    David Cavanagh
    03 9338 8191 or 03 93354008
    34 KING St
    AIRPORT WEST
    VIC 3042
    [email protected]
    16,496
    tradies will just plug the seatbelt in then sit on it ... There's going to be an electrical contact in the seatbelt catch. Just unplug and short this. This issue I imagine is in the event of an accident it may activate airbags for seats that aren't occupied
    Kim Luck likes this.
    Sep 2014
    north parramatta
    91
    I think there are a couple of things that the Peugeot computer measures:
    1. A pressure switch under the seat (There is a bum on this seat)
    2. The acceleration as you drive onto the road (perhaps it is just the gear)
    3. The seat belt socket where the contact circuit will make or break
    Every avro after lunch, I am just moving my car into the shade in the carpark just a few meters but enough to set of the seat belt alert.
    SWOTR
    3,637
    My 406 does the same thing and I have a fairly long 's' shaped driveway. Solution = wear the seat belt, it's not a big deal. Try being told by doctor not to drive for several months and you'll realise this is not such a big problem.
    mr bern likes this.
    1000+ Posts Beano's Avatar
    3,150
    When I was a cabbie, some of us used to have an old seat belt clip (from a wreck) we'd just clip in there. Or you could use a bit of plastic.
    Or just short out the wires going to the bit you clip the belt into. The car will then think there is someone belted up permanently. Just make sure you're not stuffing around with the wires to the seat belt pre-tensioner
    Melbourne, Aus.
    18,087
    I'm of the opinion as mentioned before that the seat occupation interlock controls the operation of the air-bags. Permanently preventing the operation of the drivers air-bag might produce unintended consequences.
    Jun 2011
    Brisbane Qld
    20,554
    I seem to recall reading recently of someone who deactivated the seat belt alarm via software setting. Cant recall the make of the car, but I suspect it was on this site in relation to use of one of them befangled it thingies you attach to one's motor vehicle
    lost
    11,055
    Icon6
    G'day,
    I remember reading somewhere that if your car is fitted with something, [speedo, headlights, seatbelt warning etc] that something must be operative, i.e. work. If it doesn't work, a pink slip failure could occur.
    regards,
    Les W.
    206 GTi 180
    the stealth Pug
    SWOTR
    3,637
    Seems like a lot of stuffiing around to me when you can merely use it as intended.
    UFO likes this.
    lost
    11,055
    G'day,
    yes,well, that is one alternative.
    regards,
    Les W.
    206 GTi 180
    the stealth Pug
    Sep 2014
    north parramatta
    91
    Quote Originally Posted by pug206gti View Post
    G'day,
    Hmm
    I was trying to look for some guidelines on the RMS site. There is all kinds of information but this. It is commonly called e-safety check but I doubt if it goes to the extent where each safety features is retrospectively checked. Manufacturing defects are handled by the car maker/ distributor as we know. I dont think my mechanic is going to read through the manual and check if the seat belt alert works under all conditions. Indicator lights, seat belts in working condition, headlights, brakes (brake test), tyre tread wear, wipers, unbroken seats, hand brake, seem to be the most common things checked.
    1000+ Posts mr bern's Avatar
    Feb 2003
    Melbourne (or touring)
    1,152
    I'm not sure that it's relevant to your problem, because I think its status is supposed to be reset every time you remove the ignition key, but I had a curious experience with my seat belt warning the other day.
    I'd driven home from Bunnings with something secured by the seat-belt to prevent it from falling over, and when I got home, I just removed whatever it was without undoing the seat-belt. Subsequently came back to the car, started up and drove off, noticed the (front passenger) seat-belt was still done up, so I undid it in flight ... and discovered that the warning chime just gets noisier and noisier until stopping to fix it (with the aforementioned reset) becomes preferable to a mental breakdown ... if nothing else, though, it demonstrates the mechanism's apparently total indifference under such circumstances to seat-bum-ness in determining the seat's occupancy IF you start out with the belt done up.
    MY15 208GTi
    previously:
    MY10 Sportium HDi6 and 1.6L auto
    MY99 206GTi
    MY96 306XSi auto
    MY02 Clio 1.4L auto
    1ére grenouille:
    MY5? Simca Aronde 90A
    QUICK! MORE BREAD, MORE CIRCUSES!!
    Mar 2011
    Kendenup WA
    124
    Why not just look at a wiring diagram. Or would that be too difficult?
    Pavel
    SWOTR
    3,637
    In these days of computer control I imagine that it thinks if the seat belt is done up ( and you have something in the seat), if that something is removed it would think that something is wrong therefore the audible warning.
    Feb 2003
    1,152
    Quote Originally Posted by Pavel Moore View Post
    (pats pockets) ... must've left it in my other suit ...
    MY15 208GTi
    previously:
    MY99 206GTi
    MY96 306XSi auto
    MY02 Clio 1.4L auto
    1ére grenouille:
    Don't remind me!
    16,609
    Turn the bong off with Lexia / Planet / Diagbox.
    The "coussins gonflables" are usually determined for operation (where this is a selective matter) by pressure on a sensing pad in the seat cushion.
    FIVEDOOR likes this.
    Fellow Frogger! DanielBendigo's Avatar
    Mar 2012
    Bendigo
    655
    My Ford Focus had a long constant beep. It gave about 10 seconds then just came on and ddidn't go off until seatbelt went on, reegadrdless of whether you were moving. The Clio gives a pulsating beep, but not until you start moving a certain speed.
    lost
    11,055
    Icon6
    G'day,
    at this time of the day, I'd rather turn the bong on.
    regards,
    Les W.
    206 GTi 180
    the stealth Pug
