306 Central Locking Master Control Unit Location
    Dec 2005
    HOBART
    1,265
    Default 306 Central Locking Master Control Unit Location
    I have a late 1997 (N5) 306 with defunct central locking. Well, the front passenger door unlocks when the ignition is turned on (weird).
    One of the things I want to check is the master control unit, which I suspect might be faulty. The Haynes manual talks about it being in the A pillar, and needing to remove the seat and seat belt, which I have duly done. There is no logic to the unit being there, and I cant find any cabling or unit.
    Does anyone know where the unit is located? Logically it should be behind the fuse panel below the steering wheel, but I would prefer to spend my small amount of energy looking in the right place.
    1998 Peugeot 406 D8SV Manual
    1999 Peugeot 406 D8ST Auto
    2002 Peugeot 406 D9SV Manual
    1994 Peugeot 306 XR N3 Hatch
    Over 60 Pugs in my time
    Gerry Mullock
    1000+ Posts pgti6's Avatar
    May 2001
    1,618
    Look under the rear drive seat base for the control unit.
    Fixing Peugeot 306 central locking popping up, re-opening, not staying locked.
    Lap times-
    Sandown 1 27.9
    Phillip Island 1 53.8
    Previous Frenchies-
    1988 205Gti
    1998 306 GTi6
    1997 306 N5 sedan
    1996 306 N3 XT hatch
    Dec 2005
    HOBART
    1,265
    Thanks - that was helpful. It's not the same unit but the location is correct. I'm now looking elsewhere as a new central locking unit didnt fix the problem. Probably the wiring in the drivers door or the main drivers door lock.
    Gerry Mullock
    Don't remind me!
    16,609
    I suggest unplugging the passenger door lock or disconnecting the door jamb plug first; this should isolate any wiring problems with the passenger door - the car will treat it as shut even when open, if all is otherwise well.
