306 oxygen sensor replacement
Results 1 to 12 of 12
  • 1 Post By jo proffi
Thread: 306 oxygen sensor replacement
    Member bmr306's Avatar
    Jan 2006
    Clayton
    52
    Default 306 oxygen sensor replacement
    Hey All,
    Can i get some help in locating the oxygen sensor for replacement in my 99 306 as the car keeps cutting out.
    Thanks for your help
    99 N5 306 Style. RIP
    8,426
    Usually, lack of air causes a car to stall.
    Jo
    1000+ Posts pgti6's Avatar
    May 2001
    1,618
    Is it a 1.8 litre 16V?
    It'll be screwed into the engine pipe between the exhaust manifold & catalytic converter.
    Lap times-
    Sandown 1 27.9
    Phillip Island 1 53.8
    Previous Frenchies-
    1988 205Gti
    1998 306 GTi6
    1997 306 N5 sedan
    1996 306 N3 XT hatch
    Sep 2003
    North Parramatta
    3,997
    The oxy or lambda sensor is located in the exhaust - aft of the engine and forward of the catalytic converter.
    Simon
    2018 308 GTi 2011 DS3 DSport
    www.peugeotclub.asn.au
    Melbourne Australia
    1,382
    Hi Brian
    Have you had the rest of the symptoms associated with a dodgy oxy sensor eg. rough running, horrific fuel economy etc ? If it is only stalling perhaps it may be another item. For instance if it stalls at idle it may be the Idle Air Control Valve.
    Andrew
    Oct 2005
    Rome
    2,660
    Jo
    That's helpful
    Dave
    ​1997 BMW K1200RS
    IR655
    Don't remind me!
    16,609
    True for aircraft as well.
    An oxygen sensor won't make the car stall; it will log a result of being consistently out of spec and the ECU will default to a rich pattern (map) for the fuel injection. Shorting out the sensor feed voltage might cause hiccups, but this would be easily tested by unplugging the sensor.
    8,426
    Quote Originally Posted by 68 404 View Post
    That's helpful
    Dave
    Fair enough, I was trying to keep it really really simple.
    Jo
    68 404 likes this.
    Jan 2006
    Clayton
    52
    Quote Originally Posted by pgti6 View Post
    Its 1.8L
    Jan 2006
    Clayton
    52
    Quote Originally Posted by SLC206 View Post
    thanks for the pic, where did you find this?
    Jan 2006
    Clayton
    52
    Quote Originally Posted by Andrew Ch View Post
    Hi Brian
    Andrew
    Thanks for the replay - the car is just cutting out, but i fuel economy is on the way. ill look into replacing/ a good clean for the "Idle Air Control Valve".
    8,948
    Certainly check the stepper motor and clean the valve, but I've had another thought - does the 306 gearbox share a feature with the 405? In that car there is a rotation sensor inside the speedo drive take-off. It tells the system the car is in motion. The wires give it away. If it has failed the motor stalls whenever you idle up to an intersection, red light, etc.
