306 brake ghts not working
Results 1 to 3 of 3
  • 1 Post By slgreavett
Thread: 306 brake ghts not working
    85
    Default 306 brake ghts not working
    The brake lights (all 3)on my daughter's 306 have stopped working. All fuses and globes are OK. Any ideas on what the cause might be?
    Thanks,
    Tim
    Member slgreavett's Avatar
    May 2014
    Queensland
    38
    I would be checking your brake light switch! If the fuse is good, brake light switch is next in the circuit, check power into the switch, and check when the pedal is depressed power is coming out of the switch. Only thing left apart from fuse, switch, bulbs is wiring.
    Hope this helps
    Simon
    BlackC2 likes this.
    Dec 2005
    HOBART
    1,265
    The only other option might be an earth problem, if everything else is working then it the brake light switch or nearby cabling
    1998 Peugeot 406 D8SV Manual
    1999 Peugeot 406 D8ST Auto
    2002 Peugeot 406 D9SV Manual
    1994 Peugeot 306 XR N3 Hatch
    Over 60 Pugs in my time
    Gerry Mullock
