central locking / 205 GTi
Results 1 to 14 of 14
    Fellow Frogger! felixblack1's Avatar
    May 2002
    145
    my central locking doesn't seem to work since i bought my 89/90 205 GTi last year.
    the hayes manual says it was an option, was this true for the GTi?
    Any idears on how to fix it.
    Felix
    SMP addict pugjet's Avatar
    May 2002
    Enruoblem
    2,098
    ... eyyy, felixblack1, all Australian delivered 205gtis were optioned with central locking as standard.
    The central locking will only work from the driver's side, dude - from the outside with a turn of the key or when the driver's side "button' is depressed - it will not work from the passenger end... my central locking is hooked up to my alarm, so there isnt any chance of ruining my manicure... hehehe.
    I had the same problem several months back. A little bird told me, that such things are likely to occur due to the vintage of our rampaging lions (general wear and tear). The most likely suspects are the central locking motors found on either side. You need to remove the door trim to get to the main central locking mechanism. The suspect motor was found and replaced by a non-genuine Peugeot motor (cost was roughly $45... the genuine Peugeot part was in excess of 150 bucks!). It now never skips a beat,
    bow,
    pugjet
    current frogs :
    '94 s3 alpine 205GTi
    daily ding magnet: '98 1.8 16v citroen xsara
    previous frogs:
    88 S1 205GTi
    '95 306S16
    gimme corners. . .
    Feb 2002
    Wellington, New Zealand
    78
    Yep, it could well be the motor(s). But also check the other obvious things like fuses, electrical connections into the motors, etc.
    I have this ongoing problem with mine where (I think) the motor doesn't lift the lock button high enough, then when you go to open the door from the inside, it drags the lock button back down again, locking you inside!
    Oh well, any excuse to drive it a bit further
    Unfortunately the 'warrant of fitness' testers don't quite see it that way frown
    Fellow Frogger! ipb205's Avatar
    Wright ACT
    567
    It could also be that the original infra red remote is shagged. They never worked very well new.
    I had my infra red replaced with a Vision digital un it which will unlock the doors at 30 metres not 30cm like the old infra red ones. Similar unit to the Fuego Le Plip.
    Vision or VDO do a remote kit which has an immobiliser as well.
    good luck.
    May 2002
    145
    thanks guys,
    must be the motor then. damn, i hate taking off those door covers
    1000+ Posts parry's Avatar
    Sydney Australia
    1,332
    Would anybody have anymore iformation or direction to look for the above mentioned products like vision and VDO.
    90 205 Gti Cherry Red(Track Car)
    2009 207gti
    1985 505gti (Shitbox Rally) Sold
    PBs:
    Oran Park: 1:27:9
    Wakefield: 1:05.6 (July 2015)
    Eastern Creek: 1:47 (16V) 2019
    Mt Huntley: 34.44 (2004 stock 205)
    Ringwood: 35.06 (30/10/2005)
    Winton: 1:33.6 (2017)
    nJm
    nJm is offline
    Guru nJm's Avatar
    Jan 2002
    Melbourne, Australia
    2,930
    I'd like to fit a remote to the factory central locking on my 505. Is it easy to do? I don't really want an immobiliser or alarm, just a remote control for the central locking.
    Nick
    Nick
    1983 Peugeot 505 GR
    Fellow Frogger! DTwo's Avatar
    Melbourne, Victoria, Australia
    770
    Series 3s were the first 205gtis to have remote central locking as standard apparently.....
    ________
    Bongs
    1000+ Posts silverexec's Avatar
    Melbourne, Victoria
    1,003
    Yeah, that would be very handy. Anyone on here done it?
    - Richard
    Now: 405 SRI D70 '93
    - 2.0L manual
    Earlier: 505 GTi Executive '85
    - hence "Silver Exec"...
    25 GTX '86
    - manual conversion
    Sydney Australia
    1,332
    Im looking around today for a system, I will let you know the results.
    The VDO unit looks good but I have yet to a distributer in AUS for one.
    2009 207gti
    PBs:
    Oran Park: 1:27:9
    Sydney Australia
    1,332
    The only thing I found today was a imoboliser with keyless entry included for $199. I might be going with this.
    It was a special at Strathfield car radios.
    2009 207gti
    PBs:
    Oran Park: 1:27:9
    con
    con is offline
    sydney, nsw, australia
    521
    njm,
    I bought a Rhino (RES4601) Immobilisation unit from tricky Dicky (Dick Smith) and fitted it to my 505 STi.
    It's been great as a central remote locking system (I didn't bother with the immobiliser function). Having used now for 2 years I wouldn't be without it.
    And about 10 months ago there was an article in the PCCV (and repeated in the NSW club magazine) about how to fit a similar unit to a 505.
    It's very easy to fit (I can help with advice if you get stuck).
    con....
    Sydney Australia
    1,332
    Good call con, $129 at tricy dick, ill get one tomorrow.
    2009 207gti
    PBs:
    Oran Park: 1:27:9
    May 2002
    Enruoblem
    2,098
    DTwo:
    ... did this remote central locking (from the series 3) incorporate an alarm system, also???
    I have an infra-red remote - my 205GTi is an '88 series 1 - that operates both my central locking and alarm... was this alarm (and set-up) a factory fitted option or after market? The reason why i ask is that the KEY that is used to manually turn the alarm, on and off, is done in a similar style to that of the ignition key.
    Do ya'll gets? .
    The alarm system is called "Repeller" and made in Italia.
    next vb's on me cheers! ,
    pugjet
    current frogs :
    previous frogs:
    88 S1 205GTi
    '95 306S16
    gimme corners. . .
