403 oil filters
Results 1 to 8 of 8
  • 1 Post By callipygous
Thread: 403 oil filters
    Jan 2011
    66
    Default 403 oil filters
    I've always had trouble finding the 403 oil filter cartridges, and when I have they've been ridiculously expensive. Today I found the solution. The filter you need is a WCO167 for Chrysler, Jeep, Dodge. It's quite different to look at from the Peugeot one. Instead of having a rubber seal on the bottom it has a plastic collar which with a bit of pressure clicks snugly into the base of the 403 oil filter housing. It's not quite as tall as the 403 cartridge so you need to make a thicker washer at the top. A bit of rubber fuel hose about 1cm long does the job as fits tightly over the housing bolt and makes a good seal over the top of the filter.
    The really good news is that you can get them for under $10 from here R2731P Oil Filter Chrysler 300 F2731MAF WCO167 | Direct Auto Spares
    OK I sort of lied about the price because there's postage involved. But I bought 10 of them at $9.10 but with $16.00 postage that comes to $10.70 each. You can get them on eBay for US$5 but postage kills that.
    So there you go.
    d
    Feb 2001
    Romsey, Victoria, Australia
    4,869
    We have the proper filters in stock. p/n 1109.10 for $20 each. Plus top and bottom radiator hoses too.
    David Cavanagh
    03 9338 8191 or 03 93354008
    34 KING St
    AIRPORT WEST
    VIC 3042
    [email protected]
    Fellow Frogger! callipygous's Avatar
    Jan 2006
    Toowoomba
    797
    It's best if you can get the Purflux filters.
    pugnut1 likes this.
    Peugeot 504 Intercooled T04 Turbo.
    Dec 2005
    HOBART
    1,265
    Quote Originally Posted by callipygous View Post
    Very much like the saying "oils ain't oils".
    1998 Peugeot 406 D8SV Manual
    1999 Peugeot 406 D8ST Auto
    2002 Peugeot 406 D9SV Manual
    1994 Peugeot 306 XR N3 Hatch
    Over 60 Pugs in my time
    Gerry Mullock
    9,261
    Really, most people in the PCCV have converted to the spin on 505 GTi filter (machining work required) as the Purflux filters were discontinued. Are these NOS?
    Any of the straight 203 top hoses?
    Graham
    Quote Originally Posted by David Cavanagh View Post
    Perth Western Australia
    2,694
    While I recall the number. Ryco R267P. Oil filter elements for 203. 403. 404 early 3 main engine.
    9,261
    Also, the 5 bearing engines up until 1969 when the alternators were introduced.
    These filters were also used in the overhead cam 1600 and 1850 Vauxhall/Torana, bet there aren't too many of these around nowadays!!
    Jan 2011
    66
    Anything's got to be better than the original bronze mesh ones.
