Help! 406 S3 Coupe
Results 1 to 23 of 23
Like Tree3Likes
  • 1 Post By BIGRR
  • 1 Post By Napoleon
  • 1 Post By pugnut1
Thread: Help! 406 S3 Coupe
    Member Napoleon's Avatar
    May 2012
    Hobart
    36
    Default Help! 406 S3 Coupe
    Has anybody had experience of 406 V6 2003 Coupe with intermittent "moan" (suspected) from RH Drivers side wheel area when exerting lateral force on the car such as going around a sweeping right hand bend. Not tyres. Nothing appears to be adrift underneath? Thank you.
    1000+ Posts BIGRR's Avatar
    Feb 2006
    North Rocks, Sydney
    2,441
    Does this happen when you are by yourself too? (sorry could not resist! ).
    Sounds a bit like may be a shock absorber, how many kms has the coupe done?
    Bounce the car up and down on the front guard each side (Push on a solid bit don't dent it).
    Good luck.
    lion5 likes this.
    Present fleet:-
    Peugeot 93' 205 Gti 16v
    Peugeot 73' 504 Ti from new
    Previous fleet:-
    Peugeot 95' 605 Sv
    Peugeot 92' 205 Gti
    Renault 72' 16TS from new
    Renault 69' 10
    Renault 71' 10s
    Renault 68' 10 from new
    "Be reasonable do it my way!"
    Dec 2011
    123
    Auto or Manual?
    '92 BX 16Valve (Bathurst 12 Hr edition)
    '93 BX 16Valve (Bathurst 12 Hr edition)
    '01 406 Coupe 3.0L V6 Manual
    Dec 2002
    Menzies Creek
    2,541
    1. Got enough power steering fluid in it? Are there any bubbles in the PS fluid?
    2. Wheel bearing?
    Scotty
    Melbourne - Dandenong Ranges
    2014 Peugeot RCZ - 'Remy'
    Armidale
    49
    Check the front right wheel bearing
    Jan 2011
    66
    yep. Wheel bearing would be my first guess. I had something similar (albeit on a 203) and there was no apparent slack in the bearing with the wheel on the ground, but when I spun it jacked up you could hear it.
    1000+ Posts FIVEDOOR's Avatar
    Jun 2011
    Brisbane Qld
    20,553
    I have had success in diagnosing wheel bearing issues by driving slowly 20-30 kmph and gently swerving from left to right, thus loading each side in turn, the sound should increase as the faulty bearing is loaded and vice versa when unloaded. Good luck
    Every day is a good day
    Dec 2005
    HOBART
    1,265
    Quote Originally Posted by LeRob View Post
    Auto or Manual?
    Manual
    1998 Peugeot 406 D8SV Manual
    1999 Peugeot 406 D8ST Auto
    2002 Peugeot 406 D9SV Manual
    1994 Peugeot 306 XR N3 Hatch
    Over 60 Pugs in my time
    Gerry Mullock
    Dec 2011
    123
    Quote Originally Posted by pugnut1 View Post
    Manual
    I've got an intermittent high pitched (but not especially loud) whine related to engine speed, particularly noticable in second gear (ML5T 'box), or when turning left (extends LHS suspension). Sound similar?
    May 2012
    Hobart
    36
    Funnieeee!
    This might be a bit too technical for you but I'll give it a try and get back. Can't quite see how a shock absorber could make the noise because it is a constant moan. I'll jump on the bonnet a few times that should do the trick -eh! I'll let you know.
    May 2012
    Hobart
    36
    Manual. Why?
    May 2012
    Hobart
    36
    Yeah! My thoughts to. Will do next week. Cheers.
    May 2012
    Hobart
    36
    Cheers! Will do next week. I'll let you know.
    May 2012
    Hobart
    36
    Cheers. I'll look at it next week and let you know.
    May 2012
    Hobart
    36
    Definitely not G/box.
    lost
    11,055
    Icon6
    G'day,
    worn brake pads ?
    regards,
    Les W.
    206 GTi 180
    the stealth Pug
    Dec 2011
    123
    Bottom RHS of each post - check for the quote button. Makes it much easier to follow your responses.
    Feb 2006
    North Rocks, Sydney
    2,441
    Quote Originally Posted by Napoleon View Post
    Funnieeee!
    See photo below of KONI shock absorber. The hard chrome on the shaft had worn right through and the car made the same noise you have described under the same conditions (Believe it or Not). The shock's top seal finally let go and dumped it's oil. It was not "too technical" for me to find the source of the noise then.
    Good luck with your problem and don't forget to post what you finally find is your (car's) problem.
    Present fleet:-
    Previous fleet:-
    Peugeot 95' 605 Sv
    Peugeot 92' 205 Gti
    Renault 69' 10
    Renault 71' 10s
    May 2012
    Hobart
    36
    Thanks to all for suggestions. I'll keep you posted when I get the answer. Much help from everyone.
    May 2012
    Hobart
    36
    I don't entirely understand? Obviously I'm doing this "thread" thing wrong. What does Multi quote this message mean?
    Dec 2011
    123
    If you quote the post you're replying to we can see which one of your 5 consecutive posts is replying to whom without too many mental gymnastics.
    Multi quote allows you to quote multiple posts in your reply, so you can reply to several people in 1 post.
    May 2012
    Hobart
    36
    Thank you.
    LeRob likes this.
    Dec 2005
    HOBART
    1,265
    I had a ride in the car, and agree the issue is a puzzler. It doesn't happen every time, so is hard to duplicate on demand.
    What a lovely car. You wouldn't think it's done as many ks.
    406 manual coupes are a real gem, especially in nice condition.
    LeRob likes this.
    Gerry Mullock
