504 cab coupe headlights
Results 1 to 25 of 26
    Feb 2012
    Uk
    31
    Default 504 cab coupe headlights
    HI, any one advise which is outer and inner on the old style 4 separate headlamps
    i have
    peugoet 6211.25 or valeo 450074
    and
    peugeot 6211.34 or valeo 45008
    thanks rich
    SWOTR
    3,634
    They are part of Austalian content.
    NSW
    627
    Australian content? Don't think so, just the early model.
    Rowland Pym or Thanos would be the best people to answer this.
    Adrian Wuillemin
    SWOTR
    3,634
    Could've been standard with a Cab. but was Australian content.
    1000+ Posts Mike Tippett's Avatar
    Jan 2002
    Vancouver Island, Canada
    1,751
    The outer will say "HC" embossed on the lens (dipped beam). It should have a shroud for the bulb and a dipped beam pattern on the lens fluting.
    The inner will say "HR" embossed on the lens (main beam). It will have a lot less fluting and there is no bulb shroud.
    1966 Peugeot 404 Coupé Injection post-restoration reassembly underway!
    Register your 404: https://recensement.leclub404.com/submit.php
    Fellow Frogger! julian b's Avatar
    Aug 2011
    hawthorn melbourne
    482
    It doesn't matter ,the reflectors are the same but the globe holders, which are removable ,are different ,2 low beams and 2 high beams [low beam with a shield under the globe ] The outer lights should be low beam
    NSW
    627
    Was the coupe and cab sold here?
    Adrian Wuillemin
    Jan 2002
    1,751
    The lenses of the outer and inner lights are different for sure, but the reflectors are the same.
    Aug 2011
    hawthorn melbourne
    482
    The low beam lights only come with dipping to right for continental Europe .The shield under the globe only allows light to go to the top of the reflector thus directing the light down and a little bit higher on the right side ,which may dazzle drivers in the UK. I reversed this by modifying the shields on my car . I can send photos of mod if you like.
    Aug 2011
    hawthorn melbourne
    482
    Quote Originally Posted by Adrian Wuillemi View Post
    No, only in Europe .Twice the price of sedan so low numbers.
    NSW
    627
    Thought so, that's why I questioned Peters post.
    Ps, I own a coupe with 4 lights so am interested in how you dealt with the reflectors
    Adrian Wuillemin
    651
    Quote Originally Posted by Peter Chisholm View Post
    I think you're a bit confused there. Early coupe and cabriolets had 4 separate headlights but they were completely different to the 4 separate headlights that sedans in Australia got.
    picture, 1000 words, etc.
    504 GL Coupe '73 Silver
    407 HDi Sedan '05
    Feb 2012
    Uk
    31
    Julian if you could send photos that would be great
    Feb 2012
    Uk
    31
    Great thanks, have ammased a bit of a collection mainly the HR type but have 2 HC and 1 hc lens, so can make up a set.
    should they all have internal orange glass or just main beam HR unit.504 cab coupe headlights-img_0543%5B1%5D.jpg504 cab coupe headlights-img_0542%5B1%5D.jpg504 cab coupe headlights-img_0541%5B1%5D.jpg
    Aug 2011
    hawthorn melbourne
    482
    The orange headlights were something required in France in the 70/s .Cars sold new in UK had the globe covers removed to give white lights .Depending on UK MOT requirements you may be able to leave them orange to give a French look ,or you may be able to leave only the high beam ones orange .To remove the orange cover you would have to remove the globe holder by prising it out from the back of the lens .To refit again and bend the small lugs with a small screwdriver .
    Aug 2011
    hawthorn melbourne
    482
    I will send a photo of the mods for left dipping when I have time as I have to take one light off the car to get to it .You seem to have a good collection of lights .2 look new .I wasn't able to find new ones available when I enquired a couple of years ago .[I tried Franzose and Kurt Orbie]. I had 2 spare ones and had them re silvered to as new .I think the only other cars to use the same lights are some Renault Alpine models and some 404 cabs and coupes for high beam.
    Slovenia
    198
    This is how they go.504 cab coupe headlights-imageuploadedbyaussiefrogs1410173594.557408.jpg
    Fellow Frogger! 21571's Avatar
    Apr 2013
    Geelong
    182
    Alpine A310s, both 4 and 6 cylinder were fitted with the same Cibie lights. The Vauxhall Firenza droop snoot got them too. I scored a full set off ebay UK earlier this year, or maybe last year.
    Via the aussiefrogs App
    Feb 2012
    Uk
    31
    Julian thanks, would be a great help re the modification.
    Only have 3 orange caps so have just gone for high beam
    yes been restoring mine over last 9yrs so have picked up bits along the way but everything becoming harder to find and prices always going up.
    passed its MOT last week so Saturday was 1st time on road since sept 06 !
    still got a long way to go yet and the battle with the window winders is next major issue as most of the brackets etc were rotten
    SWOTR
    3,634
    My mistake
    Aug 2011
    hawthorn melbourne
    482
    504 cab coupe headlights-globe-004.jpg504 cab coupe headlights-globe-001.jpgThis is the globe holder I have modified . The shield is to direct the light to the top only to make it shine down for low beam .The shield is lower on one side to allow the light to shine a bit higher on right of the road on the continent ,but may dazzle drivers in UK. I simply cut the high side down to the level of the low side,and added a new piece to make the other side higher . If you have already passed an MOT you may not need to worry about this .When my car arrived from UK in 2010 it had small pieces of black tape an the glass to block out the glare . Good luck with sorting out the electric windows .I wonder if anyone has managed to convert to a more modern system.
    Feb 2012
    Uk
    31
    Julian, thanks, understand the principle and have a spare holder so will have a go. Yes passed the mot but have been flashed a few times and don't like the "black tape" so looking or a more unseen fix.
    re electric windows I have tried all sorts from polo, golf, 407 etc but cant get them to fit.
    There are some units that may work but pricey https://www.a1electric.com/Merchant2..._Code=EL3000-K
    So back to the original, but i am missing some major parts due to rust etc.
    Slovenia
    198
    owen127, my lights are modified a little differently. I have no photo so I'll try to describe it.
    The globe fits into a holder and the holder into the headlight, right? Now there is a notch in the headlight into which a tab on the globe holder fits. You simply cut a new notch into the headlight and fit the globe holder in a slightly rotated position. Have I made any sense at all here? If not, let me know, I'll draw a diagram and post picture. It is a real neat solution, so worth considering.
    Feb 2012
    Uk
    31
    tonch504 yes thats clear, assume you rotate to left
    Slovenia
    198
    I'm going to say yes, but then I guess it depends if your looking from front or back.
