205 gti gear selection
Results 1 to 17 of 17
  • 1 Post By lachlanjacob
Thread: 205 gti gear selection
    Jul 2014
    25
    Default 205 gti gear selection
    hello every one. (PLEASE HELP)
    Ive been having some issues with my 93 205 gti
    Intermittently the gear selection gets jammed and I can’t select gears properly, this is also accompanied by grinding when i try and select the reverse gear, throwing the clutch back in resolved this the first time though it happened a few more times and its begging to worry my.
    Does anyone have any idea what this could be, Linkages, clutch, box, oil level ?
    any input would be good.
    Cheers.
    6,482
    Difficult, but I reckon it's possibly your clutch throw out bearing starting to fail. This can cause the clutch to be disengaged differently (less completely) some times, causing intermittent shifting.
    2003 PEUGEOT 206 GTi
    Jul 2014
    25
    Hmm ok ill add that to the list of things to check swell,
    could that cause it to become so stuck though ?
    1000+ Posts cam85's Avatar
    Nov 2003
    Bondi
    3,369
    Sounds either like a dead clutch or needs adjustment.
    Cam
    94 205 Gti Classic #9
    91 205 Si
    87 205 GTi Race Car
    Jul 2014
    25
    Cam
    also the clutch has plenty of bite and when it's not doing this jamming thing it feels great dno if that means anything though
    1000+ Posts BIGRR's Avatar
    Feb 2006
    North Rocks, Sydney
    2,439
    Quote Originally Posted by lachlanjacob View Post
    Intermittently the gear selection gets jammed and I canít select gears properly, this is also accompanied by grinding when i try and select the reverse gear, throwing the clutch back in resolved this the first time though it happened a few more times and its begging to worry my.
    Cheers.
    Check that there is no more than about 3 - 4mm slack/free play in the end of the cable at the gearbox fork lever. (Probably easiest to check from under the front).
    Present fleet:-
    Peugeot 93' 205 Gti 16v
    Peugeot 73' 504 Ti from new
    Previous fleet:-
    Peugeot 95' 605 Sv
    Peugeot 92' 205 Gti
    Renault 72' 16TS from new
    Renault 69' 10
    Renault 71' 10s
    Renault 68' 10 from new
    "Be reasonable do it my way!"
    Jul 2014
    25
    Cheers BIGRR,
    ill do that and see how I go !
    Nov 2003
    Bondi
    3,369
    If its jamming theres something wrong. A worn clutch can work when cold and not when hot.
    Where is the puck up point? Really low middle or really high?
    Cam
    91 205 Si
    87 205 GTi Race Car
    Jul 2014
    25
    Hi cam85
    the he bite point is very low hardly any travel at all
    Nov 2003
    Bondi
    3,369
    Ok. It needs adjustment. Get a 13mm and 10mm spanners. Get under the car and loosen the nuts. Then screw them in on the threaded cable until you get the pick up point about 2/3 of the way up the travel of the pedal. Having the clutch the way it is now is bot allowing it to disengage hence the grinding. It will also wear out your syncros and clutch itself.
    It will probably need about 1-2cm of winding those 2 nuts further in on the cable by the sounds of it.
    Cam
    91 205 Si
    87 205 GTi Race Car
    Jul 2014
    25
    Cam
    Brilliant. thanks mate I'll try that this arvo and see how I go !
    6,482
    Hmm, I thought by jammed you just meant difficult to engage. Do you mean the shift lever is stuck?
    Does sound like just adjustment, though, from what you've said otherwise.
    Jul 2014
    25
    Thanks everyone for their help !
    I adjusted the cable and i haven't had a problem since !
    Thanks again
    BIGRR likes this.
    Fellow Frogger! WhiteKnightGTI's Avatar
    Apr 2012
    148
    Hey guys are these the nuts and threaded cable you're referring to? My reverse gear has the same symptoms and the pickup point is also very low.
    Cheers!
    Attached Thumbnails Attached Thumbnails 205 gti gear selection-1409892394961.jpg
    1990 205 GTI
    Nov 2003
    Bondi
    3,369
    No, thats your gear linkages
    The end of the cable is behind the passenger headlight down low between the gearbox and radiator. Get on your back and stick your head under the front valance and you'll see it.
    Cam
    91 205 Si
    87 205 GTi Race Car
    1000+ Posts FIVEDOOR's Avatar
    Jun 2011
    Brisbane Qld
    20,529
    No, those are gear linkages.
    Cam85 is referring to adjustment of the clutch cable.
    205GTi's came out with two types of gear boxes (that I know of), a Be1(early) and Be3 for the later model. I have the early model Be1 gear box and it can easily be identified by the location of the reverse, which is to the left and up of the 1st gear and to engage reverse you have to lift a small lever on the gear stick, otherwise it's likely to be Be3.
    Car fitted with Be1 gear boxes, the the lever coming out of the gearbox housing is located on the front of the engine. It is reasonably low in the engine bay. I believe car fitted with Be3 this may be little different.
    The lever is circled in red in the below photo:-
    I have included a photo of the clutch cable below, which has already been disconnected from the lever in the above photo
    Edit:- Cam85, you are too quick for me. The photos might help though
    Every day is a good day
    Apr 2012
    148
    Ahh legends thanks for that. It's a BE3 but I should be good with that info now
    1990 205 GTI
