Alternator size 505
    Hobart
    1,496
    Alternator size 505
    All,
    I am building a 505 at the mo...with twin DCOE WEBBER's on it and all that other nice stuff...but the question I have is what size Alternator would be the go for this car ?
    I am planning to throw a stereo system at it...
    All I have in the shed is a 40amp I think thats a bit too small ?
    Soo any advice would be good !
    Ben
    1989 Peugeot 405 Mi16
    2000 Peugeot 306 XSI
    1973 Peugeot 504 GL
    Guru davemcbean's Avatar
    Apr 2001
    Camden NSW & Selwyn NZ
    2,334
    You would probably need a minimum of 55 amp. Some 505s have a 55 amp Paris Rhone alternator, but for my car I used some kind of 55 amp Ford Bosch alternator, which is almost identical externally to the 504 one (I think it's from either a late model Cortina or a 70s Falcon or something). I just had to change the front cover so it would bolt onto the 504 engine. To fit the 504 front cover, I just had to get some longer long bolts for the alternator (an auto electrician gave them to me for nothing).
    Dave
    NZ Fleet
    1976 504 Ti
    1984 205 GT twin carb
    1991 205 SI 1.6GTI motor
    1994 106 Xsi
    1996 Mondeo V6
    Aus Fleet
    1955 203C
    12,269
    if you are lucky enough to find one stick a 604 70amp one on it
    or there is a bosch one that puts out 85amps that you can make a rear bracket to fit
    1 x 2018 3008
    1 x 2000 Citroen XM,
    1 x '98 306 GTi6 sadly sold
    Hobart
    1,496
    Found a fully re-built 70amp from a 604.....should do the job nicely approve
    Ben wink
    1973 Peugeot 504 GL
