308 Brake lights
Results 1 to 8 of 8
    Aug 2013
    WA Perth
    15
    Default 308 Brake lights
    Man, this drives me mad :-)
    Brake lights, L and R, are not working only middle one is OK. Checked all fuses, all globes and they are all right.
    Where to start?
    Cheers from WA
    Don't remind me!
    16,609
    On your BSI, the three lights are each fed separately - probably the 40-way white plug on the BSI; look at pins 14-15-16, likely wire codes 2100 and 2101.
    Each cluster is earthed separately; I am assuming the earths are OK (put on parklights, rear fogs and hazards, look for pulsing in time with the flashers).
    I think you can also do an actuator test with Planet.
    Aug 2013
    WA Perth
    15
    Thank you addo,
    I don't have Planet , or PP2000 ....it looks like it is time to get them ASAP
    Checked other lights. Everything is ok. Earths are ok.
    Aug 2013
    WA Perth
    15
    Could not find any relays at all.
    Don't remind me!
    16,609
    There's almost certainly a solid state relay inside the BSI, it's probably the fairly contemporary version with rubberised epoxy slapped over everything. You don't have a towbar harness on the car?
    Aug 2013
    WA Perth
    15
    No towbar harness .
    I am thinking of using middle brake light to drive relay and bring live from somewhere to it . Cut original wires and bring new ones from relay.
    Would you change brake switch first ?
    Thanks again Addo , cheers.
    Fellow Frogger! Meggsy's Avatar
    351
    Problem with doing that is the CAN Bus (BSI) will interpret the additional load as a fault - hence when you install a towbar you need additional wiring with a relay box
    Meggsy
    Current - 4007HDi
    Had - 407 HDI 406 SV 404, 504, 505 GR and STI. 405 GR ( carbie version) STI, MI16
    And an Austin 1800
    Learnt to drive in 203 Convertible and a 403 SW
    Aug 2013
    WA Perth
    15
    Hmm... thank you Meggsy.
    308 XSE 2.0 HID 2009
