Peugeot 205 Timing Belt
    Jul 2014
    Sunshine Coast
    122
    Default Peugeot 205 Timing Belt
    I am interested to find out how other members changed timing belt on a 1.6 l 205 with eccentric tensioner . What did you do for the locking pin on the crankshaft according to the manual it needs to be 10mm stepped down to 8mm.
    1000+ Posts pug-life's Avatar
    Geelong
    1,226
    I'm quite sure the crank should just be 10mm. I just use what ever I can put my hands on. A 10mm drill should do the trick. DON'T try to undo the crank bolt with the bolt/drill bit in it. Lock the crank at the flywheel with screwdriver or something.
    Obviously I don't work in a service workshop
    7,487
    Yep, 10mm drill here. Lock the crank on the flywheel, else it will end in disaster.
    Jul 2014
    Sunshine Coast
    122
    I have not removed the old belt yet and have decided to check the existing settings. I have noticed that if I put the dowel in the cam pulley to lock it I cannot lock the crankshaft pulley. Also the piston is not on TDC on cylinder 1. I might add the car was running prior to deciding to change the timing belt. Am I doing something wrong?
