205 steering rack interchangability
Results 1 to 19 of 19
    Oct 2013
    17
    Default 205 steering rack interchangability
    Hi everyone
    I am wondering if a 1992 205 Si power assisted rack would bolt into my 1989 205 GTi? I won't be using/connecting the power assist parts but would the rack fit in without issues?
    1000+ Posts cam85's Avatar
    Nov 2003
    Bondi
    3,377
    Yes it fits. You will need the lower part of the steering column to join it all together. A great upgrade, do the full power assist conversion if you can!!
    94 205 Gti Classic #9
    91 205 Si
    87 205 GTi Race Car
    Fellow Frogger! Edd205's Avatar
    Feb 2013
    Aldinga
    124
    Yes the rack will fit straight in without a problem. You will probably need to unbolt the subframe to slide it in but it will all bolt up exactly the same.
    9,055
    Just for full disclosure, keep in mind that non-PS cars had a lower ratio (more turns lock-to-lock) than PS cars. If your car was non-PS, you'll get some serious arm muscles or back pain changing to a PS rack but without the power assistance. Other than that, looking at my early GTI and '92 Si wreck I would say it's all plain sailing.
    ACHTUNG ALLES LOOKENPEEPERS
    Oct 2013
    17
    Thanks guys. I will be pulling the rack off a parts car so might attempt to do the whole PS-assist conversion while I'm at it.
    9,055
    You'll need to move the alternator up too with the bracket off the donor car.
    Feb 2013
    Aldinga
    124
    That's a good point. I have this bracket as well if for some reason your donor car doesn't.
    Via the aussiefrogs App
    Nov 2003
    Bondi
    3,377
    Dont need that much muscle Schultz! 2.75 turns lock to lock with an 8v alloy motor! Easy!
    I have a plate diff, 2.6 turns and a boat anchor j4r motor! Im just an idiot though...
    In all seriousness, do the extra and plumb the power assist in. Its worth the hassle and better for future upgrade.
    Cam
    91 205 Si
    87 205 GTi Race Car
    Australia
    123
    If you run the power rack without power you will have built in delay,the torsion will have to twist to its full amount so that it can drive on the fail safe splines.
    Fellow Frogger! deltone's Avatar
    Perth
    390
    Wow wow, whats this about the lower part of the steering column??? When i wrecked the SI (it was smashed biiiiggg time) i didnt keep anything from the steering column!
    205 GTi T16
    205 CTi
    Nov 2003
    Bondi
    3,377
    The Power racks have a different connection on the steering rack itself. The early cars without power have a small spline and the Power racks have a larger spline.
    You therefore need the later lower part of the steering column to make it possible!
    Cam
    91 205 Si
    87 205 GTi Race Car
    Feb 2013
    Aldinga
    124
    That said just try it. I did a power to manual steering conversion and the splines were the same.
    9,290
    The power steering fitting fits above the rack in line with the column so the column must be shorter.
    Amazing how many people forget to keep this part of the column.
    Quote Originally Posted by deltone View Post
    Oct 2013
    17
    Thanks for the tips. I've got a complete SI so I will just swap everything from it over.
    Perth
    390
    Interesting stuff. Im always learning everyday!!
    well, if anyone has the power steering column please let me know.
    205 GTi T16
    205 CTi
    Oct 2013
    17
    Does the conversion require any wiring mods?
    Jul 2004
    803
    Nope.
    2006 Peugeot 206 Xt
    1991 Toyota mx83 grande 1jzgte
    Sep 2012
    18
    Hi all, I'd like to ask a follow up question, apologies if this should have been obvious to me.
    From the above posts it is clear the part will physically fit, but is the gear ratio within the rack the same for all power steering models, ie can I use part or all of a 205si rack to rebuild my 92 205gti, without being concerned that I'm going to loose the sharp turn-in I would expect?
    Thanks.
    9,290
    The Si rack is slightly quicker than the GTi one, 2.75 turns C/W 2.9 for the GTi.
    People say the Gti is 3.2 but I've tried two recently and they are less than 3.
    Quote Originally Posted by jamesh997 View Post
    Thanks.
