peugeot 505 turbo diesel problems no power
Results 1 to 9 of 9
    Jul 2014
    Mudgee
    9
    Default peugeot 505 turbo diesel problems no power
    have fitted new injectors and filter bowl- can't seem to bleed system of air-blows white smoke-could the waste gate be stuck open? No power getting to g/box [auto]. Any suggestions for fix appreciated as would like to be able to go on outback runs.
    9,038
    White smoke usually goes away when the engine warms up. If it hangs around it could be water from a damaged head gasket etc, or it could be unburnt diesel fuel from faulty injectors (but yours are new), bad timing, or low compression (eg the head gasket again, or crook rings or valves).
    White smoke from water doesn't smell like fuel based smoke.
    Member SamT's Avatar
    Dec 2012
    Kyneton, Victoria
    96
    What injector pump do you have. Mine would blow white smoke when it's starving of fuel...lean mix. Check your return line to see if sucking air
    Hobart
    1,496
    Are you sure it's all bled properly?
    I've had issues with getting the air out of them in the past. Bleed at the filter and then crack the lines at the injectors?
    On one of my cars I had a slightly perished hose that was letting air in the system when the car stopped.
    Cheers & good luck
    Ben
    1989 Peugeot 405 Mi16
    2000 Peugeot 306 XSI
    1973 Peugeot 504 GL
    Fellow Frogger! gromzx's Avatar
    May 2011
    melborne
    364
    If you have been working on the injectors, it might be a good idea to recheck all the fuel line are correctly fitted and that there are no cracks in the lines. It could be sucking air in from a small leak, which would produce the symptoms you are describing.
    Jul 2014
    Mudgee
    9
    should be ok but will check-thanks cal.
    Jul 2014
    Mudgee
    9
    thanks mate- will try all these things again
    Jul 2014
    Mudgee
    9
    I think it's a Bosch- will check all lines -thanks,Cal.
    Jul 2014
    Mudgee
    9
    Thanks, will have to check all this, Cal.
