New chum, Pug 403
Results 1 to 25 of 26
    Kapunda
    471
    Default New chum, Pug 403
    I am now the proud owner of a Peugeot 403 and I need some advice.1) The RHS rear door is stuck shut!
    2) Is the water circuit through the carby really necessary?
    Woody
    9,287
    Quote Originally Posted by brian woodcock View Post
    Woody
    Water circuit is needed for very cold weather to avoid icing and idling problems.
    1000+ Posts Beano's Avatar
    3,150
    If the connections where the rubber hoses connect are corroded, you don't have an option but to bypass the water circuit. It won't REALLY matter....I have done it on my 505. As long as you have a working thermostat, the engine will warm up quickly enough. It may misfire for the first 2 minutes, that's all.
    Otherwise you may hook up the circuit and have a working pre-warmer for the carby during the coldest part of Winter........ but then find that during Summer, because the connections are corroded, you blow off a hose ...... thus losing water, overheating and warping the head and blowing the head gasket.
    Dec 2005
    HOBART
    1,265
    Brian - getting door unstuck can be quite a challenge. My suggestions are :
    Remove the interior door lining (this might mean removal of the back seat squab). This might be difficult, so hopefully you might have a spare lining lying around. I assume you know how to remove window winders and the door handle?
    Squirt some penetrating lubricant onto the lock mechanism and let soak overnight.
    Work the lock loose (if it isn't already) and then work on the door handle.
    Someone like Alpine or Graham Wallis have more experience on 403s than I have and may even contradict me.
    My last ownership of a 403 was about 30 years ago, and these thoughts are standard to most models.
    1998 Peugeot 406 D8SV Manual
    1999 Peugeot 406 D8ST Auto
    2002 Peugeot 406 D9SV Manual
    1994 Peugeot 306 XR N3 Hatch
    Over 60 Pugs in my time
    Gerry Mullock
    Kapunda
    471
    Thanks for all the help guys,perhaps I better look for a spare door trim next.
    Woody
    1000+ Posts Peter C's Avatar
    SWOTR
    3,660
    My brother and I had this problem with a 403 station wagon side door. I seem to recall us taking off the trim panel and, in the end, using brute force from inside the car. It was a very long time ago so memory is abit sketchy.
    16,539
    Woody
    Do you live near Ballarat? Ask Dave about driving an old 403 without any manifold pre-heater hooked up .... It sure does get icy cold sitting on the side of the road 'cos the carby has iced up .... again .... for the 5th time in the last 20minutes.
    On the bright side, 50+ year old cars are generally only driven in good weather conditions these days. No-one wants to freeze there arse off while trying to demist an old car ........ or drive one in baking hot temperatures. So you'll probably get away without it.
    9,287
    Yes, I would connect it up.
    I drove my 203 to Eltham first thing this morning, (for its yearly Club permit check) very cold, and it ran rough and idled poorly most of the way there.
    That was with the carby sitting on top of the exhaust manifold so worse in the 403 where it is on the other side.
    Graham
    Feb 2001
    Romsey, Victoria, Australia
    4,879
    Graham
    Yearly club permit check? Please explain?
    My 403 has all its pipes connected and still ices up in temps down around zero.
    David Cavanagh
    03 9338 8191 or 03 93354008
    34 KING St
    AIRPORT WEST
    VIC 3042
    [email protected]
    16,539
    Quote Originally Posted by David Cavanagh View Post
    I bet the pre-heat is blocked up ... or full of air
    club permit check ?? Some of the clubs that love control over there members demand a "check" before they'll sign your renewal. Personally I'd find a different car club.
    Shane L
    9,287
    All to do with the rorting that has occurred, clubs being formed just to give people "cheap rego" etc. etc.
    The Historic Rally association has decided to adopt a very conservative position to reduce fall out when the shit hits the fan later this year.
    If I can get a full RWC for the 403 (see no reason why not) this will be permitted with PCCV, no need for yearly checks at the moment but possibly all clubs will be forced to do this in the future.
    Like everything in life, restrictions and rules are introduced because of people doing the wrong thing.
    If people always did the right thing we would have no need for speed limits on our roads.
    As I said , I preferred the old scheme.
    Graham
    Shane L
    Perth Western Australia
    2,694
    Would a radiator blind be effective with the carb icing? Experiment with a sheet of cardboard either half or full coverage of the radiator core. If it works a more permanent arrangement could be rigged up. Draw string operated from inside the car. [See the set-up on a 120 type Volvo Amazon].
    WB.
    16,539
    Graham
    What a load of utter bullshit. Who is doing the wrong thing?? Once isntance of a donut van that keeps getting a mention everywhere ??. Why do you think your club must police a scheme that is policed .... You know, by the police who are paid to enforce the road rules. Not you clubs personal personal rules .... 'cos they want "power" over there members.
    We've had the old CX for 18years.... It's had one Roadworthy ... that's all that's required by victorian law.. 18years ago. Yet the control freaks in clubs such as these think THEY shoudl have the power over the members to enforce annual checks on cars that would be lucky to cover a few thousand kilometers a year.
    I'd find another club, there's no way I'd want anythign to do with a club such as that. It's ludicrous to say the least. Don't worry these clubs are destined to loose there membership and fail as no-one can be bothered with this sort of bullshit. I certainly can't.
    And just think, my old CX hasn't killed anyone or been in a single accident in those 18years. Without a single check .... It's all about the clubs trying to have power of there members, nothing else.
    Feb 2001
    4,879
    Graham
    We had this talk in RCCV and it might be different with HRA where the cars get a bit of a belting but the average club car might only get driven 30 times a year, it's usally the pride and loy and doesn't got out unless weather permits so why make them get annual checks when there everyday hack does not. I agree with Shane on this one, some clubs just being little hitlers.
    David Cavanagh
    34 KING St
    AIRPORT WEST
    VIC 3042
    [email protected]
    16,539
    The sad part is car clubs are dying. This is a unique opportunity for the dying clubs to attract younger members and grow there membership.... ANd get different members in.
    It'll be everyone elses fault when there a only a couple of members left, and there average age of the remaining members is 80+ years old.... with no-one turning up to meetings/runs.
    9,287
    The Police are hopping mad, unless we really toe the line there is a chance the scheme will be scrapped entirely.
    I will stick with my club thank you.
    9,287
    No point in growing membership if these people don't contribute.
    Point taken about clubs dying though, in 20 years time there will be no clubs and associated activities, get in now while you can!
    On the other hand maybe it is just the activities people don't want given my total failure to organise an Aussiefrogs 205 get together in Shepparton a couple of years back. Great interest at first but only 1 taker, as someone said at the time, like trying to herd cats.
    16,539
    Every cop that's pulled me over to check my log book (including a TOG) has reckoned the scheme is brilliant. What cops are "hopping mad" .... I just don't know where people get this stuff from
    shane L.
    9,287
    From the many meetings and discussions with authorities over the past year or so is where.
    shane L.
    16,539
    So it's "the authorities" .... You mean there listening to all the old fuddy duddys whinging that "people are abusing the scheme... "They are driving their own cars without my personal approval ". If the police were unhappy about a car. They'd simply book every person they pulled over and throw a canary on there car if they thought it shouldn't be on the roads.
    I don't buy there being a problem at all. Let the police do there job and get on with your own life. All this bullshit happened with the last scheme too. Everyone "always new someone" that was "Rorting the scheme... it's needs to be cracked down on".... "lets bring in even more rules to make it even more unusable". The joke of the matter is the previous scheme was so pathetic and hopeless, it was pointless to even place a car on it. Also note: Every single instance of "It's being rorted"... You'd ask "who and where" new or old scheme ... doesn't matter.... And it was always a "we heard" type story. No-one actually new who it was that was being spoken about. Or even if it actually happened
    How hard is it to just leave the policing to the police and get on with your own life. I'll let you in on a little secret almost everyone else in the world has already worked out. It doesn't matter what the scheme is.... Or how it operates. The will always be a small number of poeple that use it in a way that it was never intended for.
    seeya
    shane L.
    16,539
    Sounds like your describing me. You try being a single wage earner with a young family ... Anyone that's less than 50years old is likely to have kids and 1 or 2 working parents. Just try and organise an evening a week off to go to a club meeting let alone club runs that are more than an hour from home.
    It's like the old fuddy duddies have forgotten what it was like to have a young family and no disposable income.
    I've probably been to 1 club even in the last 2years. Does that mean I'm not a car enthusiast and don't deserve to have a car on a club permit ?? 'Cos I don't meet the standards of the old fuddie duddies in clubs that reckon they should wield any/all power of anyone use of a club permit vehicle.
    I'm actually a member of 3 car clubs, but guess how meetings and club event I get too .....
    Member 404ism's Avatar
    Dec 2004
    82
    ... So Brian, any luck with the door mate?
    Quote Originally Posted by Isis View Post
    what is it about these cars that turn grown men into babies wanting a 2nd or 3rd identical rattle? now, wheres my wallet....
    9,287
    Shane, you're the one who is getting worked up about it, all I said was that I was going to my annual inspection.
    By the way, there is a tow truck in the Eltham area on a club permit, you really wonder why they haven't been booked if the police are so down on it.
    seeya
    shane L.
    16,539
    Interesting, you can have trucks on permits. The problem is he can only move around his own cars with it. He's not allowed to put business writing on it (unless it's historic) or use to for paid work. Eg: I could import this and put it on a club permit:
    But I couldn't use it to move around anyones cars, unless it was for free. I also couldn't put my tow truck business name on it. But could put on it the original tow companies french name that initially had the thing commisioned.
    Dave probably has the same problem if he got for example a "H" van, he couldn't put "French Connection" on the side of it, even if it was never used for business purposes.
    Feb 2001
    4,879
    When (If) get my Dacia ute restored I can't sign right it or do deliveries in it but I can cart my own crap to the tip or help a mate move house.
    I have a couple of mates who are highway patrol, (1 is prominant on here) both drive Fuego turbos. 1 is on club plates the other full reg. I'm fairly sure these 2 cops welcome the scheme and I'd like to hear there views.
    David Cavanagh
    34 KING St
    AIRPORT WEST
    VIC 3042
    [email protected]
