Well bugger me!
Results 1 to 13 of 13
  • 1 Post By PugMonkey
Thread: Well bugger me!
    1,376
    Default Well bugger me!
    I need to change my cam belt today due to a failed idler / tension pulley. Never done it on a 16v (in situe) before but I was showing some concern about not having the correct tension tool. Well I just discovered that the sump plug tool is a perfect fit.
    This change could not have come at a worse time.
    Via the aussiefrogs App
    Attached Thumbnails Attached Thumbnails Well bugger me!-1405215391062.jpg   Well bugger me!-1405215434508.jpg
    Wildebeest likes this.
    1,376
    I mean a square tool that can apply tension to the tension bearing. I know it's not the correct tool.
    Dec 2012
    187
    I found a 3/8 drive socket wrench did the trick for me to take the tension off the tensioner on the auxillary belt on my 306 16v.
    1,376
    I have a full set of quarter inch and half inch drives.... Lol.....
    7,487
    I use an 8mm allen key. File off two corners. It has the benefit of sitting closer. Don't forget to turn it right way. Access is much better on a 205 compared to a 405.
    1,376
    Turns out both bearings are shot so I replace them and transfer them to the new engine later.
    Nov 2012
    374
    Why didn't I think of using a socket adapter!
    Great idea, thanks!
    Jan 2005
    Melbourne NSW
    813
    This works best
    On other models the clearance between tensioner and chassis rail prevent use of larger tools.
    Current stash
    too many.
    Passed over stash
    lots.
    1,376
    Peter, what do you mean turn it right way?
    Don't remind me!
    16,609
    The top left tensioner can be rotated either clockwise or anticlockwise to apply tension.
    The underinformed rotate it the wrong way; this means belt pressure is at risk of unwinding the tensioner locking bolt.
    1,376
    Aahh ok. As per instructions, both rollers are tensioned anti clockwise against the belt. I can also see that adjusting both rollers in different ways could also alter the timing advance as the belt shortens when the bottom roller it tightened.
    1,376
    Also, PeterT's correct about the allen key. Fits much better in a confined space.
    Fellow Frogger! Mungous's Avatar
    NZ
    335
    I find the best way to adjust these in a confined space is to tweak the bolt up fairly tight so that the tensioner can still be adjusted, but not so loose that it slips back when you release the pressure on the square drive. Once the tension on the belt is correct, I then tighten the bolt.
