207 intermittent Cruise Control related to engine management issue
  • 1 Post By Morpheus
Thread: 207 intermittent Cruise Control related to engine management issue
    Jun 2004
    157
    Default 207 intermittent Cruise Control related to engine management issue
    The cruise control on my 2010 1.6 Petrol auto 207 has had some intermittent failing where it can not be set. The horizontal bars where the speed digits appear flash when the cruise control is turned on and no speed can be set. The manual says "see your Peugeot dealer........" when this happens.
    I rang the dealership and eventually got an answer that is worth remembering -
    The cruise control and the engine management systems work together and if a concern is detected with the engine computer or sensors it cuts the cruise control as a safety measure, so the cruise control problem may be caused by an underlying issue being detected by the engine’s computer.
    The problem has not disappeared. Works sometimes, doesn't work other times. Can"t seem to determine a factor that makes it behave one way or the other. Car appears to go well otherwise. No other issues.
    I've decided to leave the issue until my next service. We shall see.
    Fellow Frogger! Psychlone's Avatar
    Apr 2011
    Melbourne, Australia
    252
    I've had the same issue with my 307. Narrowed it down to misbehaving sensors on the wheels, or a bad brake switch.
    Now I have another theory. On a recent rather long (3000k +) road trip, I went to a Peugeot dealer in Brisbane who sold me a new switch, (my idea to try to fix it) but the parts guy suggested also replacing the short wiring loom between the switch and the main car loom. He said that bad wiring had been done on some of these (they're only about 30cm long) and it was causing a bad connection to the brake switch, thereby causing the cruise control to fail.
    I didn't buy it at the time because they wanted a ridiculous $230+ dollars for the loom and switch.
    I only replaced the switch, which lasted about 500km before I lost cruise control again. Now I have to find a cheaper source for a known good wiring loom, or maybe I'll try fixing it myself.
    Fellow Frogger! Morpheus's Avatar
    Dec 2010
    Perth
    195
    Yeah the 307 problem was the dodgy loom. I paid the money and had mine replaced. No more problems.
    Don't know if it's a similar issue on the 207 but I doubt it. More than likely your brake light switch on your brake pedal has been kicked off or needs adjusting. Check to see if you brake lights are on all the time. This causes the problem.
    BIGRR likes this.
    2011 Peugeot 207 HDi Touring Outdoor
    2004 Peugeot 206 XT 1.6 Manual.
    Past: 1953 Thames 100E van, 1966 Austin 1800, 1972 XA Falcon V8, 1973 Peugeot 504,
    1984 Mitsubishi Colt, Holden HX Kingswood, 1983 Toyota Corolla XX, 1988 Toyota Corolla 4WD, 2007 Peugeot 307XSE. + various company Falcauriodores.
    Next: 2007 Peugeot 407HDi Coupe
    1000+ Posts BIGRR's Avatar
    Feb 2006
    North Rocks, Sydney
    2,446
    Quote Morpheus: "More than likely your brake light switch on your brake pedal has been kicked off or needs adjusting."
    My 605 did this for while, the brake lights may not be on though I think the switch required a little clearance on the pedal.
    Good Luck.
    Present fleet:-
    Peugeot 93' 205 Gti 16v
    Peugeot 73' 504 Ti from new
    Previous fleet:-
    Peugeot 95' 605 Sv
    Peugeot 92' 205 Gti
    Renault 72' 16TS from new
    Renault 69' 10
    Renault 71' 10s
    Renault 68' 10 from new
    "Be reasonable do it my way!"
    Jul 2012
    161
    My 207 gti had a similar issue. Cured it today by removing the brake switch and giving a clean with some brake cleaner. Also adjusted the little brown tip which adjusts in and out. Refitted it. All good
    Wasn't hard too do. Brake switch located on the passenger side behind glove box. Access from Under the footwell by removing small carpet trim. There are some YouTube clips showing how.
    Lavers Hill
    317
