Peugeot 306 fuel relay
Results 1 to 3 of 3
    castlemaine
    503
    Default Peugeot 306 fuel relay
    I'm just a simple mechanical engineer, so can someone explain in plain terms how the tachymetric relay operates, specifically what is the function of the diodes in the relay.
    thanks
    roger
    Mar 2011
    Linton.Victoria.
    1,239
    Twice sent msg. but 'puter died!!-Will attempt again tomorrow.
    Mar 2011
    Linton.Victoria.
    1,239
    I'll try again----
    Tach relay senses engine motion then imparts power to fuel pump.
    Check the red lockng clip-if same as 406= as they sometimes fail.
    Had to replace one recently causing intermittent failure to operate.
