No 5th or 6th gear!
  • 1 Post By pgti6
Thread: No 5th or 6th gear!
    Dec 2010
    54
    Default No 5th or 6th gear!
    Hi All,
    I finished replacing my clutch this weekend on the 306 gti6. All is working well so far except i can't get 5th and 6th gear anymore. I also don't have to pull up on the reverse lever to get reverse. It goes straight into reverse where 6th usually is. I only removed the linkages to remove the box then connected them back on as it was going back on.
    Anyone got any ideas?
    cheers,
    Current: 306 gti6 - 2000
    Previous: 306 1.8 XR 1998
    9,050
    Engine and g'box mounts healthy? Bolts done up properly?
    Not knowing the exact background those would be the things I would check first. The same happens in various other cars when these mounts start to give in to wear or are not properly bolted on.
    ACHTUNG ALLES LOOKENPEEPERS
    Dec 2010
    54
    The lower engine mount was cracked so i replaced it with a baker BM one while it was out. I'll check the gearbox mount now that it's back on the ground.
    Is it possible that I have hooked a linkage to the wrong part of the box. I'm not sure why I can get reverse without using the pull up lever?? Thanks
    1000+ Posts pgti6's Avatar
    May 2001
    1,625
    Check the way you've re-attached the gear rods to the attached diagram.
    Attached Thumbnails Attached Thumbnails No 5th or 6th gear!-screen-shot-2014-06-29-9.03.43-pm.jpg
    pug-life likes this.
    Lap times-
    Sandown 1 27.9
    Phillip Island 1 53.8
    Previous Frenchies-
    1988 205Gti
    1998 306 GTi6
    1997 306 N5 sedan
    1996 306 N3 XT hatch
    Dec 2010
    54
    I've checked the way the linkages are hooked up and they look right to me. I think there's only 1 possible way they can go on due to their lengths.
    I'm now thinking it might be something to do with the reverse cable. It's like the collar on the shifter is stuck permanently up. Is there a special way the reverse cable has to be reinstalled?
