206 seat up/down mechanism
    1000+ Posts lion5's Avatar
    Jan 2013
    1,675
    Default 206 seat up/down mechanism
    has anyone ever dismantled a 206 seat? I have the exact same problem as this guy. My seat rocks as if it's being pivoted off a see-saw anchor. I checked underneath and noticed the pins are missing completely.
    I bought a pair of bolts and nuts thinking it'd be a simple job of throwing them in and tightening it up, but i can't get access to the inside of that pin, i have the entire seat disassembled but would I have to dismantle and remove the upholstery completely to do so?
    Don't remind me!
    16,609
    It's not super-hard to remove and refit the seat cover/foam.
    Looks as though that pressing is bent.
    Jan 2013
    1,675
    got it off, reason it was so difficult was because the lift mechanism was so buggered I couldn't get to the bolt I needed to
    mine is worse than his one See that main bar on the right end has broken off its weld.
    more crappy welds
    these seats have by far the worst design and manufacturing quality ever. No wonder the pivot bolts broke, they were either too weak for the tension they're meant to hold and/or the welding around the whole frame is shocking. You can see cracked welding all over the place. Is there any way to undo those heavy springs?
    edit: also would a peugeot 307 seat be compatible with this, need to know as ill be heading down to the wreckers
    Don't remind me!
    16,609
    I had several broken welds on the 405 driver's seat re-TIG welded, Ben at Extreme Creations did the job for me. I figured if he could stitch together turbo motorbike frames, he could weld a seat up nicely.
    If you need to borrow a hog ring kit/pliers to reassemble the seat, message me.
    Jan 2013
    1,675
    All done
    used zip ties instead of hog rings
    removed the spring unit for the lift mechanism, bolted the pivots down to the frame. Although now the seat is fixed at the height (that I drive at which is pretty much anyone unless you are 1.3m tall and need it lifted) it's steady as ever. Ended up having to buy an angle grinder. AEG makes some pretty decent stuff.
    Cheers for the input addo, a welding job would have set me back quite a bit,
    this image is old. I decided to do a decent enough job, bought myself an angle grinder and some washers and made the nut fit flat on the frame. Works pretty well, and am still amazed to see how horrible this whole design is.
    When i went to the wreckers I had a look at other lift mechanism (and slide mechanism) designs. Way way better, albeit they were from a merc and bmw.
