308 SW 1.6 THP issues
Results 1 to 25 of 26
    Mar 2005
    33
    Default 308 SW 1.6 THP issues
    Hi all,
    The 308 is using over 11 litres per 100k's.. And the wife has been driving it! Not much freeway driving.
    It's also leaking oil from the turbo feed (a common issue I believe)
    1. Any ideas what might be causing the high fuel consumption?
    2. Anyone know how long it takes to replace the oil feed? Have been quotes 5 ours (apparently exhaust needs to come off)
    3. Have PSA fixed the issues with the feed pipe if I order a new one?
    Cheers all!
    9,249
    I hope it isn't clagged up valves as happens on older models. See etuners : Technical File
    1000+ Posts TroyO's Avatar
    2,512
    Maybe timing issues?
    1000+ Posts gezza's Avatar
    Bunbury
    2,191
    Took me about 3hrs to strip down and about 4hrs to put back together when I did my oil feed on 207 gti (same engine). Its an easy just and well worth doing yourself. The fiddly bit is all the heat shield nuts that have to come maybe the 308 has more room to play with hence the 5hr quote though....
    I used a telfon braided hose with heavy duty fixings I also went about 3mm wider for better oil flow.
    To help with the carbon build up (it maybe too late for you though) I got the rcz top blanking plates and took out one pipe breather pipe and then fitted a oil catch can to the other breathers.
    I did this at 28k ish my car is now on 59k with no issues and no oil leaks.
    Ps don't get a peugoet oil feed pipe go aftermarket!!
    1990 Renault 5 GT turbo
    ####current rides####
    1994 205 gti 1.9 sorento green
    1988 205 gti 1.9 uk import grey
    2001 clio 172 sport ph1 #44/85
    1998 306 gti6. Blaze yellow
    1992 Honda Fireblade
    2013 Yamaha fzs sho Jetski
    1998 Supra RZ twin turbo white
    1999 Wrx classic gc8 sonic blue
    Mar 2005
    33
    Thanks! How long did you make the hose?
    Sounds like the blanking plate is a must then
    Bunbury
    2,191
    I took the existing metal solid pipe off and took it to a telfon braided hose place (cant remember the name) they make braided hoses for boilers and mine works etc all heavy duty anyway cost me $140 all up.
    At a guess as I cant remember now it may of been about 5inch longer than the solid pipe, the blanking plugs you just need two they are about $4bucks each you need to get them from a Peugeot rcz 2012 onwards one is on the back of the head to the left (when looing from the front of car) and it leads around to the right of the block they just twist and turn to come out.
    You will need a oil catch can for the other hose that goes to the turbo inlet hose and from the passenger side of the rocker cover just feed them into a oil catch can and all is good
    here is a picture of my set up...
    Jul 2012
    161
    Hey Portal,
    with regard to fuel consumption, I would suggest around 11lt per 100km is normal for stop start city driving. By way of comparison, my C5 with the THP engine returns 10.8lt per 100km. Citroen claims 11lt per 100km for urban conditions(which is what I consider our car to be operating in) and it drops to around 5.8lt per 100km on the highway, which I have achieved. XMy car weighs about the same as a 308SW and has a six speed auto. What year is your 308? Does it have a 4spd or 6sp auto?
    with regard to the oil feed pipe, have you tried contacting peugeot for a goodwill claim - it is after all a known problem.
    Otherwise, there is a US website called Detroit Tuned - look them up. They specialise in Mini and have developed upgraded oilfeed pipes for Mini turbos (essentially same engine as the THP). Their prices seem reasonable and are better alternative to the stock pipe.
    cheers
    Kazal
    Quote Originally Posted by portal View Post
    Hi all,
    Cheers all!
    Mar 2005
    33
    Thank you so much guys, don't have the time to deal with Peugeot so will probably order the lines from Detroit tuned.
    Do we know what model mini has the same engine? I'm guessing this is the oil feed kit.
    MINI Cooper S Turbo Oil Line KIt R56 R55 R57 R58 R59 R60 R61
    I have a 4 speeed 2009/2010 model. Thanks again guys, really helpful.
    Can you guys please recommend a good oil for this engine please? Cheers!
    Jul 2012
    161
    Portal, looks about right that kit. Maybe email them - they have bound to have sold a feed kits to pug owners. Order the little heat shield from them also if you don't have it already. What's the mileage on your pug? Are you using any oil? I am using 5/30 castrol edge as are others in this engine (mini recommend this for their cars). There is also a new Penrite oil called enviro something 5/30 - have seen it at rrpco for $55 odd. This oil is similar in spec to the total INEO oil recommended by peugeot.
    Jul 2012
    161
    Gezza, you will also need to put up a bit if a write up on the oil feed pipe job - May come in handy for some off us one day. Cheers
    Mar 2005
    33
    Quote Originally Posted by Kaza1 View Post
    It is going through fair bit of oil. 2010 model, 40k on the clock. Cheers for the help again, much appreciated.
    Mar 2005
    33
    Is the THP 1.6 the same engine as the mini N14 and N18?
    The after market pipes from Detroit Tuned are designed for these 2 engines.
    Jul 2012
    161
    I would think they the thp to about 2011 would be on par with a N14. Is the kit the same for both the N18 and N14?
    Sep 2003
    North Parramatta
    4,002
    I think the N18 is the MINI Cooper S version - as fitted to the R55 and on MINI (2007).
    The new MINI (here now or soon to be released) has gone to a 2.0 turbo.
    The N13/N14 is what BMW call it. I think this engine goes in the 116i series so may not be exactly the same, being north south and all that.
    Simon
    2018 308 GTi 2011 DS3 DSport
    www.peugeotclub.asn.au
    Mar 2005
    33
    Sure is. Safe to purchase you think?
    Sep 2003
    North Parramatta
    4,002
    The braided line should be fine - perhaps even cheaper than getting ENZED/Pirtek to make one, if postage is ok.
    You should probably consider buying the little heat shield that was a mod to the top fitting (if it's not already there).
    Item 13 in the attached pic.
    Simon
    Sep 2003
    North Parramatta
    4,002
    Apparently that site also sells an extra fancy heat shield with an added blanket. I've not seen this before. It must have come after 2011.
    https://store-zhkcqkob.mybigcommerce...e-heat-sheild/
    Simon
    Jul 2012
    161
    May be put up a quick post on the etuners website - they have lots of experience with this engine and they should be able to answer it. But given that the pipe seems to fail on both Pugs and minis suggest they are probably the same design/manufacture.
    Mar 2005
    33
    Hi all,
    Ended up install this kit: Detroit Tuned Turbo Oil Line SUPER Kit
    My mechanic commmented on how good it was, and is going to recommend it to his clients.
    No more oil leaks! Really happy with it. Thanks again for all your help, it was much appreciated.
    Jul 2012
    161
    Good to hear it well. So the THP engine is the same as the Mini N14? For future reference, how long did shipping take from the US and what was final cost? Thanks
    Kaza
    Mar 2005
    33
    It was about $40 for shipping, came within a few days . Yes same as n14 engine.
    Jul 2014
    brisbane, Australia
    15
    hey on the note of the n14 motor, has anyone fitted that updated (longer, stronger spring) timing chain tensioner.
    mini bought it out to be used on the n14 motor, after a big uproar in the states over the timing chain issue etc.
    it forces more tension on the chain and makes it work like it should.
    just seeing if anyone has fitted it.
    on this page its BMW Part No# 11317607551
    Drivetrain :: Change Your Own Chain Tensioner - North American Motoring
    Jul 2017
    Mitchell ACT
    16
    Default OIl leaks and turbo feed lines on thp 1.6t motors.
    If u r replacing the oil feed line due to leaking union o ring on the stupid genuine part, make sure u also replace the return hose and the oil filter housing gasket kit while u r in there.
    The best oil feed and return hose kit available it one u can get from eBay. Brand is MAMBO and they are Taiwan made and very good quality and a very good upgrade to fit. This brand also sells upgrade high performance turbos and are much better than the genuine brand.
    I will add a link.
    https://rover.ebay.com/rover/0/0/0?m...2F172643955989
    https://rover.ebay.com/rover/0/0/0?m...2F172696273369
    I am a Peugeot Citroen specialist mobile mechanic in Canberra and work all over act NSW and Vic. I fit these often and they are good.
    Another common problem is a worn waste gate causing a low boost Fault code. In the past a complete turbo was required to fix this. But finally now u can buy the turbo outlet housing separately for around $250 which comes off the turbo and has the new wastegate inside it. Saves replacing a turbo when the turbo is actually some thing that never fails on these, only the waste gate.
    https://rover.ebay.com/rover/0/0/0?m...2F292049634634
    Feel free to text me for any info on any problems u may have with a 1.6 turbo petrol motor or any Peugeot CitroŽn u need help diagnosing any issues with.
    0491 368 560
    Jul 2017
    Mitchell ACT
    16
    Default Intake valve carbon
    Most of the early thp 1.6 engines up to 2013 have carbon issues. The thp200 motor doesnít suffer from this issue.
    Best way to prevent it from new is to use CRC gdi intake cleaner every service as it will prevent the build up on the intake valves. And stop the oil from
    Sticking to them.
    This product is not the best for removal of heavy build up, as it uses heatsoak method and This takes time.
    Yes it uses a new PEA chemical
    That dissolves baked on oil sludge but works
    Gradually over a few thousand kms after doing the procedure.
    Best removal of severe build up is a soda blaster with soda or walnut shells of 24 grit. If u have not ever had the intake valves cleaned or maintained with the crc product at all and the cars done over 60Ē000km itís suggested to remove the intake manifold and carry out an intake valve clean.
    Also if u have a lumpy idle or hesitation on acceleration this is the likely cause. Severely covered intake valves with oil vapour thatís solidified.
    Joys of a direct injection engine that has two pcv systems and Doesnít spray fuel in the intake ports like older efi systems which wash the valves with fuel when the injectors spray.
    Many manufacturers are now using dual injection to overcome this issue. Having port injection in use in deceleration or idle conditions to wash the valves to prevent carbon build up and direct injection under load and acceleration and driving conditions.
    The best mods to do are blank off one pcv. Fit a pro vent 200 catch can to the other that goes before turbo as the pro vent by Mann Hummel is 99.9% effective and after doing a walnut or soda blast of the valves will prevent any future carbon build up from oil vapour.
    Any advice pls drop me a line. I specialise in carbon removal on direct injection engines and am a mobile Peugeot CitroŽn Renault specialist mechanic.
    Tim maher
    [email protected]
    0491368560 - text preferred
    Fellow Frogger! 207cc Sport's Avatar
    Apr 2016
    Gold Coast Hinterland
    376
    Hi all,
    Cheers all!
    2. Oil turbo feed is a RP (replacement part) now. The RP uses a ceramic washer to connect to the turbo. Can be done in two hours. Get it fixed pronto.
    1. My THP150 used same amount of juice to yours. My wife drove it mostly, but she is a bloody lead foot.
    3. Refer No. 2
    Additional: These Prince engines love spark plugs. Change them every 25,000 kilometres.
    Info:
    https://www.etuners.gr/peugeot-citro...servicing-101/
    and check this out:
    Peugeot RCZ Forum ? Dreaded carbon build up on the intake valves . . . : Drivetrain
    Phil.
    The French TartÖ 207cc Sport THP150 and now a RCZ Mk2 THP200
