Diff housing blow out
Results 1 to 24 of 24
  • 1 Post By BIGRR
Thread: Diff housing blow out
    1000+ Posts pug-life's Avatar
    Geelong
    1,226
    Default Diff housing blow out
    Hey froggers.
    I dropped the box today to do the clutch. I knew the diff housing was cracked but was unsure why.
    On closure inspection it wasn't just the diff housing that was cracked but the crown wheel was missing a substantial chunk? How? No idea, I was hoping someone could enlighten me how this could have happened.
    Luckily the two pieces missing didn't make it towards the pinion so it didn't wreck anything.
    Also the gearbox was fitted with a LSD. But I'm unsure what kind it is, so if anyone could tell me the brand and type that would be great!
    If anyone has a spare crown wheel and diff casing for sale let me know. Or please see the wanted /FS section.
    These are the photos.
    Diff housing blow out-imageuploadedbyaussiefrogs1403070220.621536.jpgDiff housing blow out-imageuploadedbyaussiefrogs1403070232.072065.jpg
    1000+ Posts pgti6's Avatar
    May 2001
    1,625
    That's nasty. Whatever the type of lsd it was it's a boat anchor now. Looks like a total box rebuild with new casing, secondary (output shaft), diff & matching crownwheel.
    What numbers are stamped onto the crownwheel? It'll be something like 14 62. Then count the number of teeth on the pinion to see if it matches the small number.
    Lap times-
    Sandown 1 27.9
    Phillip Island 1 53.8
    Previous Frenchies-
    1988 205Gti
    1998 306 GTi6
    1997 306 N5 sedan
    1996 306 N3 XT hatch
    Fellow Frogger! chez00's Avatar
    567
    It's a clutch/plate type diff - so not a Quaife. It's not a 3J either. May be Tran-X. I reckon the crown wheel is aftermarket, too, so the ratio would be different to anything anyone would have laying around. The standard ones do not have those weight reduction holes. That is very unusual damage to the crown wheel. From the photos it appears the LSD will be ok though once unbolted from the crown wheel? You may want to consider getting it properly rebuilt - it would be a shame to throw those goodies away. See my post in your for sale section for why you can't just swap things around so easily.
    1988 205 GTi XU10J4
    2001 406 Monaco 5sp V6
    tweed heads
    1,503
    Its hard to tell from the pic but ,that section showing the chunk out of the crownwheel,looks shinny as if its been moving there before it finally let go ,my guess is it was damaged when the last diff blew up and wasnt picked up when the slippery diff was fitted ,pugs
    Geelong
    1,226
    Well I've driven the car around the corner to the our other driveway (we live or a corner block) and the LSD definitely works still. No noises either. I bought the car from Sydney here not that long ago and was told that the gearbox was broken. I'd be really interested to know the history of the car because on the front of the owners manual was this (see Photo). Someone once loved it then it was left to rot.
    The car was also fitted with a Magnex back box and an exhaust with no cat. The interior was rat s##t when I got it, so I've replaced all the seats with re-upholstered S1 seats. Nice and clean.
    I can't find a matching crown wheel on the internet anywhere. The weight reduction holes are interesting I haven't seen anything like it. The closest thing I can find was this (see attached photo). The brand is BACCI ROMANO and they do final drive ratio sets. Maybe ill contact them and ask for another crown wheel . Might count the teeth now
    .Diff housing blow out-205manual.jpgDiff housing blow out-da014_4884740098.jpg
    Geelong
    1,226
    Just got a price on the Bacci Romano LSD....$2196.35 before delivery. Yikes!
    NSW
    628
    Seen lots of LSD diffs but that is a first.
    What is the car being used for? There are cheaper alternatives to that diff if you are going to replace it.
    I have rear covers if you need a new one.
    Clean the inside of the main gearbox case and have a look on the side closest to the speedo gears. There maybe some metal removed from the case to make the diff clear the case
    Adrian Wuillemin
    Geelong
    1,226
    Quote Originally Posted by Adrian Wuillemi View Post
    Adrian, are you saying you've never seen this type of LSD before?
    Whats left of the oil in the box has metal in it I think. So its kind silver and has a really really fine grit.
    The crown wheel has a 65 teeth and the pinion has 16 teeth.
    Thanks Adrian, ill keep it in mind!
    Julian
    1000+ Posts bluey504's Avatar
    Dandenong Vic
    1,260
    The chunk out of the crown wheel is a due to a poor/faulty material. It should have been billet but looks more like a pressure casting.
    The inner surface is quite grainy whilst the outer surface has an even 'sheen'. It's a cheap way of getting a reasonable product without the customer asking too many questions.....Normally there is a massive failure and you buy a total replacement as CSI can't piece together enough evidence.
    Brendan.
    1000+ Posts BIGRR's Avatar
    Feb 2006
    North Rocks, Sydney
    2,446
    Lambeth This may be the J Lambert?
    Present fleet:-
    Peugeot 93' 205 Gti 16v
    Peugeot 73' 504 Ti from new
    Previous fleet:-
    Peugeot 95' 605 Sv
    Peugeot 92' 205 Gti
    Renault 72' 16TS from new
    Renault 69' 10
    Renault 71' 10s
    Renault 68' 10 from new
    "Be reasonable do it my way!"
    9,287
    Ratio is 1.6 GTi or early 405 8 valve.
    Quote Originally Posted by pug-life View Post
    Julian
    7,487
    Somebody paid big dollars for a 4.06 cwp!
    Dec 2002
    CANBERRA
    400
    The way the LSD is bolted to the CW looks a bit like the 4.06 ZF diff that was in our car (your old 205). We could never find another crown wheel with the right bolt pattern.
    Jim
    9,287
    Would that have been the Gary Harrowfield/Simon Crane rally car?
    Gary did mention fitting a lower diff ratio.
    Quote Originally Posted by pug303 View Post
    Jim
    7,487
    Nope, I use to own that. It was Peugeot 4.06 and Quaife.
    Dec 2002
    CANBERRA
    400
    I forgot we had a PT engine but the ZF diff was already in the 205 which came from Robertson and had been a race car.
    Geelong
    1,226
    So whats the advantage of having a 4.43 FD (405 mi16) over a 4.06 FD (1.6 GTi) in the 205 mi16. If I'm going to do a swap around I want it done all at once and right. Probably should have done this when I was doing the 16v 205, but funds were the underlying factor at the time.
    Getting a crown wheel re-drilled to suit the LSD...is that a possible option. Or is that uncharted waters?
    Geelong
    1,226
    This LSD seems to be a complete set. Where by there's a recess in the crown wheel that LSD bolts to. As said earlier, if one bit brakes it's all meant to brake. Hmm....what to do
    Geelong
    1,226
    9,287
    The Mi16 box will pull out of corners better in 2nd gear but if you are just using it as a street car this is of no particular advantage.
    On the other hand the GTi box has closer ratios than the Mi16, which needs bigger gaps between gears to arrive at proper gearing in
    5th for the higher speeds.
    Feb 2006
    North Rocks, Sydney
    2,446
    My car has Mi16 gearing with 4.06 diff. I find the gearing perfect. Will do 0 -60ft at drags in 2.207s. Will also pull 5600RPM in 5th (If you are game/mad).
    The 4.43 diff would help me a little in some motorkhana tests, though I think the extra revs in gears would drive you mad on a road trip (In comparison the 4.06).
    pug-life likes this.
    Present fleet:-
    Previous fleet:-
    Peugeot 95' 605 Sv
    Peugeot 92' 205 Gti
    Renault 69' 10
    Renault 71' 10s
    567
    What a turd of a design.
    1988 205 GTi XU10J4
    NSW
    628
    Can you turn the crown wheel over and take another picture. It looks like a standard gear that has additional holes drilled in it.
    I think the piece that is broken presses into the crown wheel.
    Don't mess up the clutch pack order.
    Adrian Wuillemin
    Geelong
    1,226
    I thought the same thing until I saw that the piece that the bearing attaches to is actually a part of the crown wheel itself. And is not the other end of the LSD.
