306 S16 wont start
Results 1 to 7 of 7
    castlemaine
    503
    Default 306 S16 wont start
    I've just replaced the starter motor in my '95 306 S16. All screwed back together, but while the engine will crank, it will not fire. It appears that there is no live feed to the fuel pump fuse. Any thoughts welcomed.
    roger
    Don't remind me!
    16,609
    Got spark?
    May 2014
    Matale
    22
    check relay involved for fuel pump also check if you get spark.
    castlemaine
    503
    Quote Originally Posted by evgasr2 View Post
    Can someone advise which is the fuel pump/injector relay?
    thanks
    roger
    1000+ Posts cav91's Avatar
    Romsey, VIC
    2,340
    Should be bolted to the back of the battery box. Should be a 8mm nut and a is fairly large and brown
    Via the aussiefrogs App
    2017 Renault Koleos auto
    Fellow Frogger! FedGrapes's Avatar
    Aug 2011
    Perth, WA
    837
    306 S16 - Not Starting
    I had only one of two wires attached to the live terminal of the starter. Cranked, but no starting.
    Apr 2005
    866
    Seems likely that either something you disconnected whilst doing the starter has not been reconnected, or you've knocked something. I have a vague recollection that I may have had the same problem Fedgrapes when I did mine
    Things that I know of that will cause an S16 not to start:
    Crank angle sensor dead or disconnected.
    Plug falls off the relay on the back of the battery box that cav mentioned.
    I'd check for a dangling lead that should be connected to the battery
    Tony.
    306 S16 1995 black
    Morris 1100 1965 green
