Mi16 (1.9) ECU - Fuel Pump Switching
  • 1 Post By PeterT
Thread: Mi16 (1.9) ECU - Fuel Pump Switching
    Don't remind me!
    16,609
    Icon7 Mi16 (1.9) ECU - Fuel Pump Switching
    Waking old Paris from a three year sleep today, I had to remove the fuel pump relay cover and hold the reed in at first, to get fuel pressure. After a bit, it stayed pulled in. Now to fix the "running on two" plug well full of water...
    Is the relay coil ground (off the ECU) switched by a transistor or solid state relay?
    I've seen plenty of faults online where people had neither fuel nor spark, but I had a big healthy spark the whole time I was fiddling about. The connector pins all look passably clean and positive feed was OK - or am I just looking at a dodgy crimp?
    7,487
    Mi16 (1.9) ECU - Fuel Pump Switching-xu9j4z_ecu.jpgM744 is switched to ground by the ECU. Goodness knows what's inside the ECU pulling it to ground.
    addo likes this.
    Don't remind me!
    16,609
    That's what I'd concluded (by torchlight, after looking at the dubious layouts in Haynes' Book of Lies). My concern was whether I was on the edge of a recurring problem known to others, or just a teething issue with a dormant engine.
    7,487
    I'd just wriggle all the crimps first and change the relay.
    Don't remind me!
    16,609
    Ta; that was my line of thinking if it happened again soon.
