504 Petrol gauge Erratic swinging from Empty - Full - etc
Results 1 to 9 of 9
  • 1 Post By ipb205
Thread: 504 Petrol gauge Erratic swinging from Empty - Full - etc
    Jun 2004
    157
    Default 504 Petrol gauge Erratic swinging from Empty - Full - etc
    The petrol gauge on my 504 has just started intermittently flicking from full empty to full full (so to speak) - that is - way past its normal "full" position (and the tank is full - filled it up a day or so ago). No obvious cause - eg going over bumps. Never notice this before. The gauge has otherwise behaved itself for the last 35 or so years!
    Any suggestion as to where to start looking for the problem, and hopefully, a solution?
    Avisford NSW
    550
    Replace the tank sender.
    San Diego, California, USA
    3,543
    Pull the sender and see if the float hasn't self-destructed.
    Fellow Frogger! ipb205's Avatar
    Wright ACT
    567
    Ive had this before too. The Auto electrician earthed the guage and cluster to the steering column (or some close by metal) via an additional wire. Problem solved.
    Ive got a brand new 504 tank sender unit if you cant find one in Melbourne. They may be no longer available.
    Ian
    con likes this.
    May 2014
    Matale
    22
    Hey man , I would be happy to get a sender/floater for my 504 , if you have it I can pay via paypal . Its really hard to find it here.
    thanks man .
    12,269
    i earth the 604 fuel guages to fix their erratic problems
    1 x 2018 3008
    1 x 2000 Citroen XM,
    1 x '98 306 GTi6 sadly sold
    Fellow Frogger! Tom_95's Avatar
    Jul 2011
    Sunshine Coast, Queensland
    204
    My fuel gauge jumps around depending on acceleration/braking. I thought this was normal...
    1975 Peugeot 504 GL | 2018 Suzuki Swift GLX Turbo
    1000+ Posts Beano's Avatar
    3,150
    In the sender unit, there is a small card with resistance wire wound around it, and an arm which moves on top of this. When they get old, the windings bunch up, and this may be the cause of jumping around.
    I've often wondered if it might be possible to correct this by taking it apart and re-winding it, sticking the wire onto the card with superglue or fibreglass. I wouldn't want to stuff it up though....the pressure on the little arm probably needs to be exact....otherwise it will either not connect, or press down too hard, wearing out the windings.
    Jun 2004
    157
    Thanks Ian
    I'll trace the earth - I realise that I've been too lazy over many years to actually put in the two bolts holding the instrument cluster to the dash. Taken the thing on and out too many times to bother......Serve me right, perhaps
    I'll try to look into it.
    Barry
