sump plug tool
Results 1 to 25 of 29
Thread: sump plug tool
    12,265
    Default sump plug tool
    in the hunt for a sump plug tool i have just been on the phone to snap-on who happen to have the 8mm tool needed for the 404/504/505/604 in case you guys ever need one
    they are around the $25 mark
    i'll be picking mine up form the mobile snap-on bloke next wednesday while he is on town here
    just thought i'd let you guys know that have been using filed down 3/8" extensions and have been having trouble trying to get one through a dealer of which i used to have one branded facom but alas have misplaced it somewhere
    1 x 2018 3008
    1 x 2000 Citroen XM,
    1 x '98 306 GTi6 sadly sold
    Wodonga
    928
    Icon7
    I've been using a bit of high speed steel that is used for making the cutting bits on metal lathes. It's about 70mm long and about 8mm square. You can tap it into the plug and get a shifter onto it to get the plug out. The mild steel tools seem to bend and get all rounded and become useless. I cost me nothing as I have a friend who works in a machine shop.
    Matt.
    CitroŽn Tragic UFO's Avatar
    9,738
    That is one (very good) method that I used up until recently. A friend in France sourced the tool bar for me and it is probably just a chrome plated version of the same thing with a 45 deg bend in it near the socket end.
    Cost about $15 each landed.
    Mind you, I'm yet to use it as I had only just oil changed the XM before it arrived. Oil change due again in a coupla weeks
    12,265
    Quote Originally Posted by Ralph
    Matt.
    be careful using HSS as when it breaks it shatters and little shards can and will go anywhere
    i'll let you know how i go with the new tool from snap-on
    i have never had troubles with any snap-on gear in the past
    the last genuine one i got from pug cost $17
    1 x 2018 3008
    Wodonga
    928
    Icon7
    Yep, I'm well aware of the dangers of HSS. The trick is to place the shifter as close as you can to the sump plug to minimise torsional forces on the HSS and reduce the chance of shattering. The usual eye protection etc. should be used and try to look away when you start turning the plug.
    Some of those sump/diff/gearbox plugs are tight little suckers! The design of them would have to be one of the sillier things I've seen. I remember a thread a while back where someone suggested to replace them with ones off a Jap car or something.
    Matt.
    9,223
    If only they'd had a 10mm square hole, then we could have used a 3/8" socket wrench and/or extension!
    I have thought about grinding down a very good Allen key to suit...
    7,483
    That's what I've been using since I lost my snap on tool. Just file a bees dick off points of an 8mm allen key.
    Netherlands
    17
    I used to use a doorhandle....
    I dont know if doorhandles have a different size over there form the european ones. But the male handle of a set has an insert that fits the plug.
    [edit] I mean a door as in the kitchen door etc, not a car door ;-)
    Fellow Frogger! Saru's Avatar
    138
    How is the "right" tool different to the sump-plug spanners I've seen at autopro?
    The ones I've seen are black powder coated steel with a profusion of various sized knobs on the end, presumably for different shaped/sized bolts.
    '94 405 Mi16
    12,265
    Quote Originally Posted by Vegas
    do the ones at autopro have an 8mm square for the pugs ?
    1 x 2018 3008
    Fellow Frogger! Atan's Avatar
    261
    I've got a real one from a pug dealer when I had a 505 sti. It works a treat, last price paid was about $25 - $30 many years ago. I cried blue murder when I paid for it but it is better than stripping the plug using the wrong size tool.
    Does the 306 s16 use the same tool? If not I may put it into the trading post for frog parts since I dont have use for it anymore
    2007 VW Jetta 2.0 TDi 6sp manual
    2001 VW Bora 4-Motion - flooded away
    1998 Peugeot 406 SV manual - Gone to Hail Heaven
    1994 Silver S16 - Gone
    1983 505 Sti - Gone to good home
    Aug 2002
    1,290
    Quote Originally Posted by Atan
    For 30$ you could buy a bloody long length of 8mm high carbon steel cut, bend and if you wanted harden and temper it to suit, Sell them off for 5 - 10$ each and make a killing. (Peter T sounds like a good metalwork class project what do you reckon)
    Neil
    '94 405 SRBT
    '82 CX 2400 Pallas 5spd
    '76 CX Super
    '05 WL Statesman
    '92 HZJ80 Landcruiser
    12,265
    one of the ones i used to have was a 1/2" drive one
    it was great getting into the coolant plugs on the sides of the PRV engine
    the other one i had had an 8mm square at each end and was an L shape whci i of course then bent the other end to suit making g/box plugs easier to get in and out
    but alas both are lost so time for a new one
    but i really miss the 1/2 drive socket type one i had as it was very handy
    1 x 2018 3008
    Moderator Alan S's Avatar
    Queensland, Australia
    8,923
    They've got every size but 8mm on them....now, wanna guess what size you need???
    Alan S
    261
    Alan S
    You are right! They are either too small(rattle in the hole) or too big. That's why I gave up and paid $ for one that fitted
    12,265
    well hopefully the snap-on van is in town today and i'll have the right tool again
    1 x 2018 3008
    261
    Here is image of sump plug tool that I have used for 8 years
    12,265
    thats the same as the one i used to have
    when i got mine it was an L shape and i bent the other end to suit
    1 x 2018 3008
    138
    Bugger
    '94 405 Mi16
    12,265
    just an update the snap-on van comes through here next wed so i still have to wait a week
    1 x 2018 3008
    261
    mine was pre bent when i bought it from Regans, the longer end has 6mm block while teh short end is 8mm
    9,223
    Originally posted by cruiserman
    For $30 you could buy a long length of 8mm high carbon steel cut, bend and if you wanted harden and temper it to suit, Sell them off for $5 - $10 each and make a killing. (Peter T sounds like a good metalwork class project what do you reckon)
    Aren't the handles for most piston ring compressors that size?
    Wonder how hard they are?
    The other thing is the ones from Auto-Pro... I don't think they'd be powder coated, but if they have a section that's too big, grinding them back to the right size shouldn't really hurt them... should it?
    I was just thinking, though, I have a nice 14mm Allen key I bought many years ago for taking the plugs out of the 504 cranks to clean the sludge traps out. If I cut 45mm or so off the handle of this, I could then grind one end down to size and use it in conjunction with a 14mm socket.
    You can get any number of large Allen keys for next to nothing at markets and second hand junk shops...
    5,220
    Hi, looks like frog cars have 'temper proove' sump plugs.
    Our R19 has as well. Just got a metal bar from a locksmith and filed it to size. For the auto plug, which is a weird shape, i made a cast with body filler first. The key quality metal bar is up to the job and it is cheap. I think i payed $5.
    JoBo
    1000+ Posts N5GTi6's Avatar
    1,101
    Yeah - sell it. Modern Pugs just use a socket.
    '07 C3 Exclusive
    '10 308 Sportium Touring
    '12 Megane RS265 8:08
    9,223
    Good tip, JoBo...
