406 shaking
Results 1 to 25 of 35
Like Tree10Likes
Thread: 406 shaking
    Fellow Frogger! 505604's Avatar
    Junee, NSW
    818
    Icon8 406 shaking
    I'm out of ideas. My mechanic is out of ideas.
    My 406 HDi has, since about 380 000 km, had a shaking which seemingly comes from the rear end.
    The shaking starts quite mildly at a little over 50 km/h and becomes really pronounced at about 70 km/h. It goes away (completely) at about 75 km/h.
    Suspected was the trailing arm bushes and so these have been replaced. Also replaced were the rear suspension link bars. On the front, all subframe mounts have been replaced. The right hand side engine mounts have been replaced - separate story.
    The car has had new tyres and wheels and has also had a front wheel alignment. The rear tyres aren't wearing in a manner which indicates that the rear needs aligning. (I'm not even sure if they can be aligned.)
    After all this, the shaking still remains, but the car feels really tight, and the mechanic says that he's been under the car and pushed, prodded and shaken everything that he can and there isn't any movement.
    If you have any (sensible!) ideas as to what could be causing this shaking, I'd love to hear from you
    Andrew
    Current cars: Peugeot 307 HDi Touring; Peugeot 306 Cabriolet; Peugeot 406 HDi, Peugeot 505 Familiale
    Previous cars: 1965 Peugeot 404; 1972 Renault 16TS; 1970 Peugeot 504 1800; 1978 Peugeot 504 GL; 1976 Peugeot 504 LTI;
    1984 Peugeot 505 Familiale; 1982 Peugeot 604 (converted to TD) 1999 Peugeot 306 Cabriolet (better car than the 2002 model we replaced it with)
    1000+ Posts bluey504's Avatar
    Dandenong Vic
    1,272
    First go to Pedder's and get the $28 dollar suspension check done, even for fresh eyes on the problem. Road trip to Albury or the next nearest branch after that, surprise them as such.
    Second check rear brakes; rotor thickness and runout both inside and out (Ford problem but you never know!), pad wear and pistons being sticky to return.
    Finally, Are the tyres/wheels round? No joking here, I've not seen it all but feck me I've seem most of what can happen. Tyres not seated in the bead, bent rims (easy to spot), radial runout in the wheel or tyre ie buckle, incorrect weighting and the CSI favourite failed tyre sealant or the lack of removal.
    Brendan.
    Junee, NSW
    818
    Thanks, Brendan.
    I've changed from steel wheels to alloys and put new tyres on. Surely, even if both sets of tyres and/or wheels had problems, the shaking would at least have changed in some respect. But still worth checking those things again.
    Thanks for the ideas about the rotor thickness etc. and yes, a fresh set of eyes isn't a bad idea, either.
    Cheers, Andrew
    Dec 2005
    HOBART
    1,265
    The rear end alignment should also be checked. It's easy for the tyre place to adjust. If the rear drop links need to be replaced, get that done first.
    1998 Peugeot 406 D8SV Manual
    1999 Peugeot 406 D8ST Auto
    2002 Peugeot 406 D9SV Manual
    1994 Peugeot 306 XR N3 Hatch
    Over 60 Pugs in my time
    Gerry Mullock
    Junee, NSW
    818
    Hi Gerry,
    The drop links - as you call them - have been replaced.
    If the rear alignment was out, wouldn't that cause uneven rear tyre wear? My tyres are wearing very well/evenly.
    Thanks for responding.
    Andrew
    Dec 2005
    HOBART
    1,265
    Quote Originally Posted by 505604 View Post
    Hi Gerry,
    Andrew
    In that case this probably isnt the issue.
    Sometimes a wheel out of round or out of balance will produce a front end shake. Other than that, I'm out of ideas!
    Gerry Mullock
    Oct 2005
    vic
    858
    Have seen tyres out of round many a time. Spin rear wheels whilst mounted on hub with a screwdriver or ruler up close to the spinning tread but not touching. If the tyre/rim is out it will be really obvious.
    Junee, NSW
    818
    I've changed tyres and wheels (as per first post). Nothing changes.
    Someone (not on here) suggested driveshafts. Anyone know if and how a driveshaft could cause this problem?
    Thanks,
    Andrew
    Jul 2003
    bundaberg
    353
    Yes it is possible, we had a 406 HDI Auto that began to rattle items in the driver's door pocket at about 70 kph. Very strange. Car was traded soon after but followed up with the dealer who spent lots of time tracing the problem. Eventually swapped a driveshaft from another 406 and the problem vanished. Cause? During our ownership the car was shipped away for work on the Al4 as part of the extended warranty. It transpired that an original driveshaft boot had been replaced with a non original one. New owners still in love with the 406 three years later.
    Geedee
    BIGRR likes this.
    Blue Mountains, NSW
    438
    A bent driveshaft/axle can certainly give a car the shakes. Doesn't really sound like your problem since they tend to get worse with speed. What speed does the shake seem to be at? Drive shafts will run at wheel speed. At 60kph that's something like half a dozen bumps per second, and will vary with road speed, but not with gear. Does anything change if you knock it back a gear when the shaking's happening?
    I know you say it seems to be coming from the rear, but these things can be deceptive.
    Have fun,
    Rob.
    1000+ Posts lion5's Avatar
    Jan 2013
    1,675
    Driveshafts usually are balanced by design or balanced on the manufacturing line, but it would have to be some extra weight or dent that is large enough to cause the thing to actually go out of balance.
    1000+ Posts cav91's Avatar
    Romsey, VIC
    2,341
    Worn out cv joints could do it. Specially the inner on the right hand shaft.
    Via the aussiefrogs App
    2017 Renault Koleos auto
    Sep 2003
    North Parramatta
    4,008
    If you are certain it's the rear that's shaking - could it not be the handbrake drums in the rear discs?
    Perhaps after 380,000km they are no longer optimal roundness, or something
    Simon
    2018 308 GTi 2011 DS3 DSport
    www.peugeotclub.asn.au
    Fellow Frogger! stew's Avatar
    Apr 2011
    brisbane
    496
    I reckon you should pull out both front driveshafts, get the inner joints apart and check for wear patterns in the grooves. It appears to me it could be a drive line shake under high torque. A pattern of wear can occur where under higher load the cv ball will travel up and over a wear ramp in the ball grooves in the inner joints. This makes the engine shake side ways across the car. That then feels like the arse wobbling. Any sign of rusty grease is a tell tale.
    BIGRR likes this.
    Don't remind me!
    16,609
    Well put; a neat explanation.
    Junee, NSW
    818
    Thanks for the input, everyone. Very interesting and helpful.
    I'll get to these things in the coming weeks and report on progress/outcome.
    Andrew
    1000+ Posts BIGRR's Avatar
    Feb 2006
    North Rocks, Sydney
    2,460
    Quote Originally Posted by stew View Post
    Daughter's 2000 XSi 306 auto had same problem, very similar symptoms to 505604s. The 306 had only done 120000km. Reco drive shafts fixed it completely. 505604s, 380000km is big mileage from a drive shaft!!!
    Also the 605 would do a similar shake if you drove it and forgot to take the handbrake completely off. Could be related to hand brake?
    And ... I have noticed on all the Pugs fitted with ABS that the back pads wear before the fronts???? Pull the ABS shunt and test drive?
    Why do we drive bloody Pugs??
    addo likes this.
    Present fleet:-
    Peugeot 93' 205 Gti 16v
    Peugeot 73' 504 Ti from new
    Previous fleet:-
    Peugeot 95' 605 Sv
    Peugeot 92' 205 Gti
    Renault 72' 16TS from new
    Renault 69' 10
    Renault 71' 10s
    Renault 68' 10 from new
    "Be reasonable do it my way!"
    Junee, NSW
    818
    Quote Originally Posted by BIGRR View Post
    Because they're the best car on the road, problems and all.
    Junee, NSW
    818
    Quote Originally Posted by robs View Post
    Have fun,
    Rob.
    Hi Rob, sorry I missed your questions earlier.
    Yes, I realise that things - location - can be deceptive.
    Shaking starts at a bit over 50 km/h, is really bad at about 70 km/h, and goes away completely by about 75, maybe 80 km/h.
    Driving yesterday, it seemed that the shaking was worse under load. Again, it seems that it is speed related. I'll have to try coasting in neutral and also with the car in gear but the foot on the clutch.
    Have fun, you say? I'm not!
    Andrew
    Fellow Frogger! julian b's Avatar
    Aug 2011
    hawthorn melbourne
    482
    Get someone to follow you and see if the shaking is evident from the rear .At least it could show which wheel is shaking. I have the same problem on a Merc 380 SEL hire car I drive [I don't own it] .It was shaking in the front at 80 km/s ,even after wheel balance and after swapping wheels from front to back .The problem is still not resolved.
    Albion Park
    59
    [ G'day Andrew
    I have come across this in the front on trucks and Vans on many occasions
    in my experance it had been Shock absorbers even though they looked ok they would get a cacitation in them .
    giveing you a vibration that would only go away after backing off .
    Have not experances it on the back yet.
    John P T
    Coffs Harbour, NSW, Australia
    625
    The inner drive shaft universal joint accommodates plunge. Any restriction there will give vibration at wheel rotation speed, varying in intensity as the shaft angle increases, especially under load. Ideally the drive shaft should be as near to horizontal as possible, but load, braking,road irregularities & aerodynamics will affect that, front & rear.
    I experienced this problem in my Citroen GS on a trip when towing a camper van some years ago. The inner front universal spiders have balls with needle rollers, & despite there being plenty of grease in the joint , it can centrifuge away from the needles, letting them dry out, get hot, expand, & lock up.
    In this case I was lucky enough to catch it before the bits destroyed themselves, so a good polish & refill with teflon grease with some added gear oil to keep it fluid, solved the problem for good. The other side was on the way too & received the same treatment for a permanent fix.
    I am unfamiliar with the 406 shafts, but if there is any restriction on plunge [ in out movement ] you will get vibration.
    Richard
    Aug 2019
    Macedonia
    1
    Did you solve the problem????
    Junee, NSW
    818
    Quote Originally Posted by diesell76 View Post
    Unfortunately, not yet.
    Do you have a solution? Or do you have a similar problem?
    Mar 2011
    Linton.Victoria.
    1,268
    Very interesting.Boot must have been savagely out of round,??
