604 brake calipers on a 505
Results 1 to 10 of 10
    1000+ Posts silverexec's Avatar
    Melbourne, Victoria
    1,003
    I'm going to change my front calipers next week and was intending to buy a pair of 505 Teves calipers to replace my crappy Bendix ones.
    The thing is, one day I'd like to get ventilated front rotors which can only be used with 604 calipers. Can 604 calipers be used with the standard 505 solid rotors I have now?
    It would save me from buying the 505 ones now and then having to dump them later on for the 604 ones.
    Richard
    - Richard
    Now: 405 SRI D70 '93
    - 2.0L manual
    Earlier: 505 GTi Executive '85
    - hence "Silver Exec"...
    25 GTX '86
    - manual conversion
    12,269
    you can buy new vented/grooved or just vented 604 rotors from DBA or order them through your local repco outlet as they are stockists for DBA
    1 x 2018 3008
    1 x 2000 Citroen XM,
    1 x '98 306 GTi6 sadly sold
    9,223
    Putting some packing (securely... ie, weld it) behind the pads might enable you to do it...
    Best bet would be to put an old backing plate behind the pads you instal. You'd only need to put a couple of tack welds top and bottom and you'd be right. Of course, you'd have to clean all the remaining pad material off the backing plate.
    Melbourne, Victoria
    1,003
    pugrambo:
    Cool, the problem is I can't afford to get them at the moment... Hence the plan to get the calipers now and the rotors later.
    Ray, thanks for the tip. By welding on some backing plates to the pads, is there a chance of introducing some negative traits like vibration or squealing?
    Richard
    - Richard
    - 2.0L manual
    25 GTX '86
    - manual conversion
    9,223
    Grease the sides and backs of the pads if there is... that fixes that.
    If you get them nice and flat on the back of the new pads you should be right... put them into a vyce to weld them. Their sole purpose is to prevent the pads from falling out once they wear too far for the retainers and to prevent the pistons popping out.
    In other words, you're making up for the reduced thickness of the disc by putting more meat onto the pads. You'll find there's a bit of a safety margin there.
    Melbourne, Victoria
    1,003
    Ok then. I'll probably go ahead with it, but some other financial issues have cropped up so I won't be doing it for a while.
    Thanks for the help.
    Richard
    - Richard
    - 2.0L manual
    25 GTX '86
    - manual conversion
    Melbourne, Victoria
    1,003
    Just to confuse things a little more...
    I called up the guys at EBC to find out the price of 604 pads (and to cancel my order for 505 Teves pads), and was told that the 604 and 505 Teves pads have the same order number. In other words, the pads are identical. question
    Wouldn't this mean that the calipers are the same?
    Or is the 604 caliper actually wider (to accomodate the ventilated rotors) while still using the same pads?
    Richard
    - Richard
    - 2.0L manual
    25 GTX '86
    - manual conversion
    9,223
    It has to be wider...
    Actually, I think Dave McBean posted something about this a few weeks back.
    Could be wrong...
    Guru davemcbean's Avatar
    Apr 2001
    Camden NSW & Selwyn NZ
    2,334
    Ray Bell:
    Could be wrong...
    Yeah, I did. The calipers are almost identical except for the fact that the 604 version is wider to accomodate the wider discs. So spacers are needed as Ray mentioned, if you want to fit the wider caliper to the solid disc.
    Dave
    <small>[ 15 July 2003, 10:00 AM: Message edited by: davemcbean ]</small>
    NZ Fleet
    1976 504 Ti
    1984 205 GT twin carb
    1991 205 SI 1.6GTI motor
    1994 106 Xsi
    1996 Mondeo V6
    Aus Fleet
    1955 203C
    Melbourne, Victoria
    1,003
    Aha, so ordering in those 505 pads wasn't a waste of time.
    Thanks for the info, hopefully I'll be able to get things going over the next few weeks.
    Richard
    - Richard
    - 2.0L manual
    25 GTX '86
    - manual conversion
