Possible clutch problems
    Aug 2003
    58
    Icon4 Possible clutch problems
    Hi all,
    I have a problem with my Pug 307 manual. on standing starts it feels as if the clutch is 'slipping', the engagement of the gears doesnt feel at crisp as like it was when it was new (which wasnt that long ago!). The gears dont seem to engage as precisely as some other cars i've owned and driven.
    On hills even when i give it more gas the car seems to struggle from take off ofter jerking/struggling a bit.
    Does anyone have similar problems or could give suggestions for this? or is this a peugeot trait?
    Thanks in advance
    Tim
    Fellow Frogger! MadBiker's Avatar
    Nov 2003
    Griffith
    194
    it could be that the clutch needs adjustment after its worn in?
    Gordon, NSW
    4,527
    I've always found the 307 clutch to be quite vague. It doesn't help that the accelerator lacks a lot of feel being a fly-by-wire device.
    It's a hydraulic clutch, so it wouldn't be the cable, would it? I don't know if a hydraulic clutch has a cable, the GTI6 had a cable clutch only, as your 405 Madbiker.
    - Lincoln
    392
    My 306 has a cable clutch.
    How many Km/l?? the car done
    And if its not that old just get peugeot to sorted out, unless they find it to be your clutch plate is burnt out and may say its a wear and tear item so may not be covered by warranty.
    Good luck
    Aug 2003
    58
    The cars only done about 13k km's so far and i dont drive the car that hard.
    Quote Originally Posted by immy s16
    Good luck
    Fellow Frogger! J206GTI's Avatar
    Jun 2003
    BIG Gravel Island
    357
    I think since 206 all the RHD got hydraulic clutch. As the LHD RHD conversion won't fit the cable ???
    does the clutch pedal bounce back when you release it ?
    I had a grabbing clutch like that before on my 206 and the dealer changed the clutch cylinder, then it works fine since. It might need a ube with the linkages every now and then...
    hope this helps...
    Jason
    Jason
    206 GTI MY01.5 Oversteer Edition
    Myth Buster Logic : red cars go faster !!
    Red Car Bling factor :
