405: Water coming in through front interiour light
Results 1 to 8 of 8
    Fellow Frogger! Saru's Avatar
    138
    Default 405: Water coming in through front interiour light
    Hi,
    It rained farily heavily in Canberra last night and as the Pug is still waiting for the RX-7 to vacate the garage it slept outside. This morning on the way to work I noticed a few drops coming in through the front interiour light. It seems to me that the water probably came in through somewhere near the radio antenna. Has anyone else had this problem?
    The pug is a MkII mi16 if that makes any difference.
    Ben
    '94 405 Mi16
    2000+ Brad's Avatar
    2,404
    Yep, I get it VERY occasionally and only when it rains for a while. I thought it was coming through the windscreen surround, which on mine is not securred fully. A simple fix when I get around to it is to run a line of sealant under the surround. Try to see if you can pull yours up.
    Aug 2002
    1,290
    Quote Originally Posted by Vegas
    Hi,
    Ben
    Had the same problem with mine on a trip to Qld in Sept water ran in through the light fitting during very, very heavy rain much harder than in CBR last night. I believe that the sunroof drains could not cope with the amount of water.
    Neil
    '94 405 SRBT
    '82 CX 2400 Pallas 5spd
    '76 CX Super
    '05 WL Statesman
    '92 HZJ80 Landcruiser
    Oct 2002
    Adelaide SA
    18
    A friend had the same problem with their 306 XT, turned out to be blocked sunroof drain holes. I assume your car is fitted with a sunroof?
    1995 306 S16....now has a new home.
    2003 Astra Turbo
    Tadpole pimp daddy mi16's Avatar
    12
    100% sure it is the sun roof drain holes
    why oh why did i try will be the cry when the guy in mi passes you by
    138
    Brad - will have a look at the windscreen surround tonight.
    I am 100% sure my car does not have a sunroof. I suppose I should have said in my first post.
    The water was coming in through (around) the interiour light just behind the central rear vision mirror.
    '94 405 Mi16
    2000+ Brad's Avatar
    2,404
    I'm pretty sure my car has no sunroof, I have never looked actually.
    2
    Default 405 Leak in interior light
    This has happened to me a lot. I thought it was sunroof drain holes and had it pulled out to double check, but no problem and it is hard for this to be a problem really.
    the real problem was a poor seal in the roof mounted aerial, and rain was forced under the seal and into to light. (I remember reversing out from under a tree and catching the aerial as I went)
    Cheap fix to doproperly, so filling it up with silicone would be desperate short term measure.
