Removing steering wheel 405
Results 1 to 11 of 11
    Fellow Frogger! kaiser's Avatar
    Sep 2003
    Canberra ACT
    393
    Default Removing steering wheel 405
    Hi Ppl
    Anyone know of a trick to removing the steering wheel on an MI16?
    Tried bashing it but it wouldnt budge.(I removed the nut first of course )
    Any tips??
    Ky
    Fellow Frogger! matt205's Avatar
    498
    Quote Originally Posted by kaiser
    Hi Ppl
    Any tips??
    Ky
    Try rocking it side to side, if it's never been off they can get sticky! Some WD on the splines may help as well.
    Matt
    "Imagine watching the entire French Air-Force crash into a fireworks factory. That's how much fun this car is."
    Jeremy Clarkson - talking about the V6 Clio
    Fellow Frogger! Mitch Mi16's Avatar
    Oct 2003
    Sydney, Australia
    568
    What you replacing it with Ky???
    THE MAD PUGGA
    1989 405 Mi16 (PGT-405)
    Fellow Frogger! tasgill's Avatar
    Toowoomba
    290
    Loosen the nut a couple of turns, use your knees to hold pressure on the steering wheel towards you, and using a hammer and drift gently tap the steering shaft.
    This advice does not apply if you have an air bag.
    Terry
    Fellow Frogger! Jez 405's Avatar
    542
    Hi Ppl
    Any tips??
    Ky
    Loosen the steering wheel nut a few turns, but leave it on so you don't brain yourself when the steering wheel pulls free.
    Hold the top of the wheel, and whack the bottom out with a rubber mallet. Then hold the bottom, and whack the top.
    If that fails...
    Wind down the drivers' side window. Place right foot on A-pillar/doorpost.
    Grasp steering wheel by the hub or spokes and PULL.
    (Make sure the nut is in place!)
    1987 Peugeot 205 GTI S1
    1996 Jaguar XJR X300
    1991 Honda VT250 Spada
    1992 Peugeot 405 S (R.I.P. 31/07/2005)
    23
    Default st wheel removal
    Yep, leave the nut on the end of the spline a bit to prevent the wheel coming off with force and knocking out all ya teeth!!! Ouch!!!
    If the wheel looks likes it aint gonna budge go get a steering wheel puller from supercheap or similar place...should be about $10-12 and worth the money. It's the only way. Had to do this on another project car where the wheel had not been off in 40 years....spent days nearly injuring myself. Got a wheel puller and it popped right off in 5 minutes.
    Good luck.....
    Sep 2003
    Canberra ACT
    393
    Thanks Guys I'll give it another go.
    Ky
    Ps just as well I didnt get it off as I took the nut off completly
    12,265
    Ky
    you only do that once
    when you realise that you have the wheel embedded in your head you sit and wonder why you didn't leave the nut on a few turns
    1 x 2018 3008
    1 x 2000 Citroen XM,
    1 x '98 306 GTi6 sadly sold
    Sep 2003
    Canberra ACT
    393
    Quote Originally Posted by Mitch Mi16
    Just a standard one mitch, thats in better condition. Nothing fancy
    Ky
    Fellow Frogger! MadBiker's Avatar
    Nov 2003
    Griffith
    194
    STOP!
    dont belt it off..
    i did that with a commodore once, and it damaged the stearing rack by breaking a seal and bearings in the rack..
    food for through..
    cheers
    Nathan
    1991 Peugeot 405 Mi16
    1994 Toyota Camry CSI
    2002 Honda CBR600F4i
    1989 Honda CD250U
    www.mad-biker.com
    Sep 2003
    Canberra ACT
    393
    Quote Originally Posted by MadBiker
    STOP!
    dont belt it off..
    food for through..
    cheers
    Nathan
    Its all good I got it off
    Ky
