307WRC.. now with pitures !
Results 1 to 9 of 9
    1000+ Posts tekkie's Avatar
    Jun 2002
    1,516
    Default 307WRC.. now with pitures !
    From Pistonheads website:
    Peugeot’s new WRC contender will compete for the first time shortly in the gruelling Monte Carlo Rally. This year, Peugeot’s two-time World Champion, Marcus Gronholm, will be joined by exciting Belgian driver ‘fast Freddy’ Loix.
    The new car – based on the 307 CC – will replace the successful 206 WRC that has dominated the scene for so long. It uses an all-aluminium 2.0-litre engine that develops up to 300 bhp at 5,250 rpm with 390 lb-ft of torque at 3,500 rpm.
    humm, err.. mmmk. But why choose a larger car when you have a 206? Isnt power to weight be all in motorsport?
    Doesn't make too much sense from the marketing point of view either, when you released a 206GTi180, but have no equivalent ball tearer in the 307 range for people to flock to.
    Aug 2003
    Dubbo
    14
    there's a great article in this weeks Auto Action about the 307 WRC, including a 2 page picture in the middle of the mag...
    Bart - "Gee Homer you sure do suck tonight"
    Homer - "Suck like a fox!"
    Now - 2003 Peugeot 206 GTi
    Then - 2001 Peugeot 306 Rallye
    Aug 2003
    Dubbo
    14
    also i'd suggest that there are new car regulations for WRC thus why they arent using the 206 any more...
    1000+ Posts pgti6's Avatar
    May 2001
    1,618
    Default Re:307 WRC
    Quote Originally Posted by tekkie
    Hey Tekkie,
    bear in mind a 307 shell only weighs 307Kg and there is a 320Kg minimum weight for any WRC car body shell, so the weight penalty for the CC body isn't an issue. In fact the added rigidity inbuilt into the CC floorpan may be of technical benefit to the cars performance. The final built up car sits bang on the 1230Kg minimum weight with balast added.
    (lifted from-http://forums.nasioc.com/forums/showthread/t-457587.html)
    Even though the model choice was made for the Rally Team by the marketing dept., a bigger car is not necessarily a bad thing-an opportunity to redistribute the weight and the newer XU7JP4 engine allows them to run a longtitudinal transmission, thus enabling quicker replacement/servicing.
    I see Peugeot as leaders, rather than following the pack in moving to a different ('tho seemingly heavier) base car.
    I agree that the project is somewhat undermined with no hero car in the 307 range.
    Maybe a 250hp 4wd turbo to regain some lost ground.
    My worth!
    Jeff
    Lap times-
    Sandown 1 27.9
    Phillip Island 1 53.8
    Previous Frenchies-
    1988 205Gti
    1998 306 GTi6
    1997 306 N5 sedan
    1996 306 N3 XT hatch
    Jun 2002
    1,516
    Love this forum !
    post a comment (well rally a question as to why a 307) and one gets an answer
    The minimum weight... humm, ok, but a lighter car gives more freedom to redistribute the added weight to wherever the team feels will add the balance benefit. Unless the minimum weight of the shell has to be "as from production line", most probably to stop hybrid carbon/alloys look-a-likes.
    The wheelbase is definately a problem if the WRC has set a limit (as it seems apparent).
    I always thought that the hardtop has more inherent rigidity over the the coupe .. you know box structure will always be stronger then a flat u channel.
    cheers for the heads up about the new regulations.
    Auckland, New Zealand
    108
    Default 307WRC
    The new 307WRC is both the same weight(min.) and the same width as the 206WRC it replaces, it differs by being longer, which clearly gives the techos more room for tranmissions. This in turn makes for quicker & easier servicing.
    The team have apparently homologated a 4 speed & a 5 speed Hewland g/box.
    Also it seems the torque is delivered at lower rpm than in 206, so they expect to make fewer gear changes. That being the case thay may use a stronger 4 speed box for beefed up reliability in suitably fast rallies-more likely on gravel than tarmac i would think. I can see Marcus taking this car by the scruff on gravel. Alez Peugeot !
    Don
    Fellow Frogger! Gak306's Avatar
    135
    Great picture!! Never liked the car in red though!
    It just goes to show how far behind the times we are in this country, Peugeot hold back the 206GTi180 for what reason I don't know, when they finally decide to release it in this country, there is a press release about the new 307cc rally car, which still isn't available in this country.(Officially, But there are a couple here!)
    P.S. Buy the way has anyone seem the new Peugeot that just came into the country it arrived on the last shipment...................it's the 203 and it has a am radio!!
    XTC
    XTC is offline
    Mar 2003
    Location Location Location
    8,566
    Quote Originally Posted by GTi180killer
    It has a wireless !!!! Wholey smoke !
    - XTC206 -
    Now this is a .sig
    Fellow Frogger! Mitch Mi16's Avatar
    Oct 2003
    Sydney, Australia
    568
    In another post, i put up a link for some video footage...
    can't remember which post it was... if anyone wants the link... PM me..
    THE MAD PUGGA
    1989 405 Mi16 (PGT-405)
