Fusibles
Results 1 to 9 of 9
Thread: Fusibles
    Jan 2002
    S.E Melbourne, Australia
    262
    Fusibles
    Does anybody know where the fuse for the fuel pump is on a 505 series 1 GTi???
    Jason Judd
    <img border="0" alt="[Peugeot Emblem]" title="" src="graemlins/peugeot.gif" /> '85 505 GTi Executive
    <img border="0" alt="[Peugeot Emblem]" title="" src="graemlins/peugeot.gif" /> '88 205 GL 1.1
    Nov 2001
    1,640
    Its behind the ashtray, Jason. Seriously.
    Rod
    Rod's Home Page
    Rod's car page
    Jan 2002
    262
    Umm... No. On the series 1?
    Jason Judd
    Jan 2002
    262
    From the Haynes manual, i see that the Fuel pump fuse is behind the ashtray at the centre of the dashboard, but i have no idea where it is in the Series 1. The original manual say's it's fuse 6 in the box, but that is a "spare" according to the Haynes Manual, and it does nothing when you remove it.
    Jason Judd
    Nov 2001
    1,640
    Well, I could be wrong, Jason (I'm just going by Haynes myself) , but I still reckon its behind the ashtray in the series 1 as well as the series 2. Its item number 186 on the Haynes wiring diagram on page 267 - which looks like its well and truly inside the passenger cabin. For some reason they haven't referred to it in the index to the wiring diagrams.
    See also page 236 of Haynes, which seems to be referring to all injected vehicles, not just the S2. On the series 2 at least the fuse carriers sometimes pop out backwards, behind the area that the ash tray mounts in (very annoying) , so if you can't see it, this could be the reason.
    Then again, the diag on 267 is probably a LHD car, so maybe I could be wrong.
    Rod
    <small>[ 06 June 2002, 04:45 PM: Message edited by: Rod Hagen ]</small>
    Rod's Home Page
    Rod's car page
    Fellow Frogger! 406_SV's Avatar
    Queensland
    173
    It's actually under the dash - there's that interior lighting rheostat thingy which pops open, and the fuse for the fuel pump is amoungst the ball of wires behind it.
    there - when I'm not raving about tyres like everyone else, I can share a thing or two (perhaps) about fuses wink
    Jan 2002
    262
    Ok, it's definantly NOT beahind the ashtray, and if it's behind the rheostat cover, then it must be hiding real good... Ahh well. I'll keep lookin, cause it's gota be in there somewhere
    Jason Judd
    Queensland
    173
    I have a series one 85 GTi and I'm pretty sure that's where it's hiding - when I installed the cruise control on the car I had it to pieces and came across it - you may need to pull down the cover under the steering wheel and have a closer look. Just had a look in the manual for the car, and it says its *somewhere* around the rheostat wink
    Jan 2002
    262
    Yeah, i'll have a look... Bit of an inconvienient place to put it though
    Thanks,
    Jason Judd
