405 Mi16 mods
Results 1 to 14 of 14
Thread: 405 Mi16 mods
    5
    Default 405 Mi16 mods
    Hi,
    I have owned a 405 Mi16 for a month now and I'm interested in doing some mods to it. First to mind is a K&N but I've heard that the Mi16 intake/filter system is excellent and putting a K&N setup on will not improve performance at all?. Is this true?. Already has an upgraded exhaust system and muffler, although the cat hasn't been removed. Removing the cat is a bit dodgy for getting a WOF etc, but adds 10hp apparently?.
    Does anyone have good knowledge of Mi16 modifications and can recommend what is the best performance/price mods to start with to setup around 200hp. Currently around 165-170hp. Without having to spend $4000 on a Haltech computer etc,..
    Also if anyone knows of a good Peugeot performance garage in Auckland, NZ that would help too.
    7,483
    Quote Originally Posted by mangist
    Hi,
    A couple of questions first. If you've got 165-170hp why does it have a cat? Which model Mi16 is it? XU9J4, XU9J4Z or XU10J4?
    One thing is for sure though. Unless your handy with the spanners and can do a lot of the work yourself, you won't get a genuine 200hp (flywheel) without spending near $4000.
    5
    Mmm,
    For $4000, might as well sell the car and spend $12k on a 400hp rotary . Why would it cost $4000 for 40hp? That seems ridiculous especially with the Mi16 head. Ported, enlarged valves, race cams + k&N setup for $2000 will surely give 40hp? Any idea if you can get turbo kits for these in NZ or Aus because there do exist turbo 405s.
    damn.
    12,266
    Mmm,
    damn.
    you could well do that and join the mobs of sheep
    or
    you could stay different and blow them away when you find that next corner
    also you won't have service station constipation either
    your choice
    good luck
    1 x 2018 3008
    1 x 2000 Citroen XM,
    1 x '98 306 GTi6 sadly sold
    7,483
    You didn't answer my questions. That info determines the cost.
    NSW
    1,063
    What about fuel pump, injectors, fuel pressure regulator, something to run the engine because the standard computer sure isn't going to do it with race cams.
    I guess you could just use the factory stuff for a while until it blows up.
    Fellow Frogger! kaiser's Avatar
    Sep 2003
    Canberra ACT
    393
    Mmm,
    damn.
    mangist
    Porting and larger valves alone do not give you much of an increase unless you have the UK spec engine with the higher compression. I have done this recently after snapping my timing belt and found only about a 5% increase(this is estimated as I did not have a before Dyno) Peter and I have been talking about a re ground inlet cam which will hopefully give more of an increase, still using the standard ECU and will hopefully make better use of the flow potential of the head.
    If you are currently making 165-170Bhp, there must be some exsisting Mods as the standard Mi16 has 145 bhp (XU9J4Z motor with Cat)
    Removing the cat makes no difference what so ever, with maybe the exception of a slight increase in economy( so I'm told )
    Ky
    Cal
    Cal is offline
    Moderator Cal's Avatar
    Jan 2002
    1,624
    Take the A/C compressor off and put a blower there instead.
    Cal.
    1995 Mazda MX5 - 2F Race Car
    1990 Mercedes 300TE
    1990 Mercedes 230E
    1977 Jaguar XJS V12
    1971 Morris Mini 1100K
    1967 Porsche 911S
    1957 Porsche 356A Speedster Replica
    2000+ Brad's Avatar
    2,404
    Quote Originally Posted by Cal
    Cal.
    Yeah, you like your superchargers don't you Cal
    Fellow Frogger! Mitch Mi16's Avatar
    Oct 2003
    Sydney, Australia
    568
    Cal.
    Gimme, Gimme, Gimme... hehehehe
    THE MAD PUGGA
    1989 405 Mi16 (PGT-405)
    Tadpole pimp daddy mi16's Avatar
    12
    I own a phase 2 mi-16 xu10j4 i have a straight through stainless exhaust system,custom induction kit modified from a sierra cosworth rs500 (huge induction noise) and i have a rolling road print out of [email protected] fly a stage 2 head,uprated cams and a full port and polish will easily see u at 200bhp with out a doubt i should point out mine is a uk car
    Oct 2003
    Sydney, Australia
    568
    I refer back to my last post... Gimme, gimme gimme.. hehehe
    THE MAD PUGGA
    Northern ireland
    1
    there is a company in england called prism motorsport who can make up a turbocharger kit for the mi16 and it is estimated to give you between 220 and 240hp. You can then ad a big valve head which has the potential to go too 300hp if not more. I was on the phone to him today and he said he can get you more hp if you want but it will cost loads. Standard turbo kit is about 4000 all in.
    5
    i have a 309mi16 kicking out 168bhp with just the standard engine..k&n and a 4-2-1 manifold onto my scorpion...
    going turbo with this engine can be a lot of hassle as its an ali block...na is the best approach.....
    decent tb setup is around 2500 including fitting and mapping....
    big valve head and cams...around 1500
    85mm forged pistons..about 600 iirc
    and if you use the lot and lighten/balance your bottom end you'll be around 230-240bhp and the car will still be fairly traffic friendly
    http://www.pumaracing.co.uk/pug16v.htm
