206 RC Brakes -
Results 1 to 16 of 16
  • 1 Post By DRTDVL
Thread: 206 RC Brakes -
    Mar 2011
    Brisbane, QLD
    137
    Default 206 RC Brakes -
    Too hard basket!!! Pug needs new pads n disks, stock calipers on the rear with EBC red pads n slotted rotors, have 406 brembo conversion up front with im assuming still 283mm rotors and red stuff pads, what to buy to replace, cooking my brain!
    PUG 206 GTI 180
    AEGEAN BLUE
    OZ RACING ULTRALEGGERAS
    BREMBOS
    ACHILLIES 123S TRACK RUBBER
    AST SPORTLINE I
    AST SOLID TOP MOUNTS
    EMS EXHAUST
    EMS TUNED
    AP CLUTCH
    PHILLIPS HIDS
    GENUINE MORETTES
    IPOD CABLE
    DYNAMAT
    107 fwkW DYNO'D 2012
    1000+ Posts cam85's Avatar
    Nov 2003
    Bondi
    3,393
    Stock everything unless your on the track otherwise pointless as holes in boat. Ditch the slotted drilled stuff as the metals are usually rubbish. Get some brembo rotors for the front in the same size. Leave the rear standard as it will be more efficient. Youll never over heat them on the road. If you are your driving too fast or theres something wrong.
    94 205 Gti Classic #9
    91 205 Si
    87 205 GTi Race Car
    I might be slow... DRTDVL's Avatar
    Auckland
    1,288
    Brembo pads are just Ferodo pads rebranded.
    Mar 2011
    Brisbane, QLD
    137
    they are all Brembo rotors already, have reordered Brembo rotors but not the slotted ones, my track play dates are far n few between these days, cheers for info guys
    PUG 206 GTI 180
    AEGEAN BLUE
    BREMBOS
    AST SPORTLINE I
    EMS EXHAUST
    EMS TUNED
    AP CLUTCH
    PHILLIPS HIDS
    GENUINE MORETTES
    IPOD CABLE
    DYNAMAT
    Fellow Frogger! Brett's Avatar
    Nov 2001
    618
    I am currently running Ferodo DS3000 fronts with slotted discs. Pads are wearing much faster than the discs.
    I get two or three track days before pedal travel is a bit disconcerting.
    I was thing of going to Pagid or Endless. I have a set of 406 Brembo I was going to change to at last resort.
    Any other suggestions?
    Sorry for hijacking
    Via the aussiefrogs App
    Bathurst______2 57.22 Sandown_______1 35.29
    Mallala_______1 22.90 Phillip Island____1 56.41
    Winton_______1.43.90 Collingrove_______38.08
    The Bend Int__2 21.96 The Bend GT ___3.58.12
    https://www.facebook.com/FrogstompRacing/
    http://www.harlandeng.com.au
    976
    Yeah, I use DS3000 for track days, and stock peugeot pads day to day. Ruined a fair few DS2500's, still on the first set of DS3000.
    Nov 2001
    618
    My track days are at Mallala.
    Which is renowned for being harsh on pads.
    Fellow Frogger! runabout's Avatar
    129
    agree with Cam here I've been running red stuff for a year now biggest waste of money I've spent once these have run out I'm going back to pagid oem spec pads on my VTS which I've had before from E.C.P UK but will keep my brembo disks these seem to last longer then the pagid disks I ran before.
    Auckland
    1,288
    Quote Originally Posted by Brett View Post
    Is it pedal travel because of the pads or because the fluid is dead?
    I tend to find it's always the fluid that causes the pedal travel in my cases. I've spoken to a couple old rally guys who commented about putting a small soft spring in the piston to help stop the pads from moving back to far as the seals on the pistons would pull the pads back away from the disc face.
    Nov 2001
    618
    I think the main problem is the pads are wearing unevenly.
    As the pads are tapered when the pressure is off they spring back leaving a large gap.
    The take up of the gap is causing the pedal travel.
    The spring idea is interesting.
    I pull a wheel off and work out some dimensions in next couple of days.
    Thanks,
    Brett
    Auckland
    1,288
    Make sure the slides are clean, lubed, and working properly.
    When you have the wheel off also get someone to push the brake pedal and have a look at the movement of the pads.
    addo likes this.
    1000+ Posts bluey504's Avatar
    Dandenong Vic
    1,269
    Quote Originally Posted by DRTDVL View Post
    Subaru used a similar set-up in Group N Rallying, it really is an "Anti-knock off spring". The rating is really low IIRC, something like 2 to 3 pounds of force. Just enough to keep the pad up to the disc but not enough to engage/drag the brakes.
    If you can eliminate pad knock back any other way that's fine. Ron Harrop made a swivel foot pivot so early Torana's didn't taper wear the front pads when racing.
    Brendan.
    Nov 2001
    618
    Pagid and Endless don't a pad.
    So I have ordered Ferodo DS Uno
    Nov 2003
    Bondi
    3,393
    Or change your calipers for gti6 items. They don't tend to wear the pad unevenly like yours do.
    CL pads are what I want!! Just too expensive
    Cam
    91 205 Si
    87 205 GTi Race Car
    1000+ Posts lion5's Avatar
    Jan 2013
    1,675
    Are you guys using custom brake lines? Won't pedal travel increase if you're using stock rubber brake-lines as they expand (thus reducing fluid pressure)
    Nov 2001
    618
    Yep,I am running braided lines.
    Never ran rubber on this car.
    But it made a big difference on one of the others.
