Clutch cable - 306
Results 1 to 25 of 37
    Jun 2011
    50
    Default Clutch cable - 306
    Seems my 306's clutch cable is knackered. Where would be the best place for me to get another, that'll be open over the Chrissy/New Year period? I'm in the eastern suburbs of Melbourne.
    I've called Peugeot, and the cable's $116. They're about $65 delivered on eBay (but I'd rather not wait two weeks for it to ship from the UK). I've called up the local Repco, and the bloke there suggested that they could make a cable up, but I'd rather get one that's designed for the car.
    As I've got no working car at present, something within walking distance of public transport would be nice
    Sep 2003
    North Parramatta
    3,997
    The usual Melbourne suspects would be French Connection (Airport West), EAI and AutoParis (both in the Box Hill area, I think), I would imagine.
    Simon
    2018 308 GTi 2011 DS3 DSport
    www.peugeotclub.asn.au
    Jun 2011
    50
    OK, my problems might be a bit more than the clutch cable.
    Long story short, last weekend the clutch pedal went to the ground, and promptly stayed there. Waited two hours for a tow-truck to get the bastard home.
    Now I'm having a go at fixing it. First I thought the cable would have snapped, hence the above post. Seems OK, there's still some tension in the cable.
    Then I noticed that the clip on the pedal had come off. I put the clip back on and tried pressing the pedal down. Still went almost all the way to the ground before noticing any resistance.
    Now I thought maybe the issue is at the other end, and promptly removed the cable from the other end to see if I could do anything. Thing is, I don't know if I've put it back correctly! I've attached a picture of how it is now.
    Worrying thing is I pull on that cable and the silver arm doesn't move at all. I can easily move the arm around with no resistance (although the car is out of gear). Does that mean my clutch is buggered?
    Could someone please shed some light for me? Thanks
    Attached Thumbnails Attached Thumbnails Clutch cable - 306-photo-23-12-2013-20-50-58.jpg   Clutch cable - 306-photo-23-12-2013-19-32-30.jpg
    CitroŽn Tragic UFO's Avatar
    9,738
    I'm betting that the shitty plastic framed thrust bearing has collapsed and you are now rooted. It's a gearbox off jobby to replace clutch, thrust bearing, thrust bearing shaft (thingy) etc. Getting that locator pin out of the clutch lever arm is a right pr1ck of a job too. More than likely you will find the cable is perfectly ok.
    10,945
    Quote Originally Posted by Deanodriver View Post
    Our 306 cable has a self adjusting mechanism either attached or part of the cable. I reckon $116 is pretty reasonable (about 6 oil filters) and ours has lasted 19 years so far, so about $6 per week. Bird in the hand I reckon, especially if the cable Peugeot supply matches the VIN number of the vehicle. They sold far more 306 variants in UK, so whether you get exactly the right cable from there would bother me a bit whilst waiting.
    Bad time for it to break! Good luck with the replacement. I'd ponder a bit on whether the clutch is getting heavy and on the way out too, but you'll perhaps find the new cable gives a lighter touch.
    And I agree with Craig's post - might just be that it isn't the cable.
    Renault 4CV 1951
    Renault R8 1965
    Renault Scenic 2005 (wife's)
    Renault Scenic 2007 (mine)
    CitroŽn CX Pallas 1980
    Jun 2011
    50
    I'm fearing that you're right. If that's the case, then I'll be getting rid of the thing. It's not worth spending however much that'll cost to fix, when the car's got a litre-a-fortnight oil habit.
    Something else that may well support your theory. For the last few weeks, there has been a light grinding sound when pressing the clutch in.
    I'd be inclined to buy locally for the faster shipping times alone, but I guess I'd best find out whether the cable is at fault.
    9,738
    Oh yes, it'll be the (lack of) thrust bearing. I know as we had almost exactly the same thing happen in the Xsara that we had (same engine/box as yours). Only a few months after we got it sorted a bloke ran into the back of it one morning. Ended up being written off.
    7,483
    Interesting. I've just purchased a 306 and intend to convert it to the more serviceable push type adjustable clutch, as found on 405/205. I'm hoping the 306 pedal will accept the 405 cable. Will find out after Christmas.
    Jun 2011
    50
    Thanks for that
    Hmm, gives me a bit to ponder then. It does sound like the thrust bearing is at fault, although I may well get my mechanic to look over it to confirm it for me.
    Brings me to a tough decision. I could either spend the money on getting it fixed and going (with the intention to trade it in soon), or I could cut my losses and get rid of it now.
    Given the other issues with the car, I'm actually leaning towards the latter. That said, if it's only a few hundred to get it going again...
    9,738
    If you're dextrous and/or have one of those remote inspection cameras, it is possible to pop off a couple of plastic covers on the side of the 'box to get a look inside the bell housing before dismantling.
    Jun 2011
    50
    Neither in my case, unfortunately.
    Jun 2011
    50
    I actually managed to get it moving (by rolling it until it was fast enough to slot into first). Not the best idea if I'm at all honest, but I managed to move it to another spot.
    I'm just thinking as to whether I'll get it towed to my normal mechanic for a quick diagnosis (in case it's not the thrust bearing), or get someone local to do it.
    If it is, then I'll have to work out what to do with the thing.
    Apr 2005
    866
    How many KM's has it done. When my diff blew and I pulled out the gearbox the clutch was absolutely knackered. I'd done about 235,000KM I think.
    The thrust bearing had pretty much collapsed, shortly before the diff blew I think the thrust race collapsed which led to some crunching of gears, and a very heavy clutch pedal.
    Pulling the gearbox out was a big job for me, but I got there in the end. Getting the job done by someone else will likely cost as much as an other car. With the 1 Litre a fortnight oil habit unless you are really attached to the car I can understand not wanting to spend the money to fix it.
    I definitely considered getting rid of the S16 when the diff/gearbox exploded, but decided that I had nothing to loose by trying to pull it out myself, and with the help of the great folks here at aussie frogs (and about 2 months of elapsed time) I got it back on the road. All up I probably spent about 2K on parts (1K on the quaif LSD) but it was worth it.
    Tony.
    306 S16 1995 black
    Morris 1100 1965 green
    Jun 2011
    50
    Quote Originally Posted by Wintermute View Post
    Tony.
    It's done just over 210,000km.
    I'd considered doing it myself, but not having a proper garage or some of the tools doesn't work in my favour there.
    I guess if the issue was just the clutch, I'd get it sorted. However, I've used two or three bottles of oil in the last 10,000km, and there were a few other things identified by my mechanic at the last service that would soon require attention. Taking the clutch, fixing the oil consumption issue (which I think is either something with the head or worn rings), and the other things into account, I think that sorting all of those would cost more than simply getting another car.
    It overheated twice a bit over a year ago (as per this thread: Leaky 306), and hasn't been the same since.
    Jun 2011
    sunshine coast
    3
    gents, help please? Like the person who started this thread, my clutch also went just before Christmas, (Christmas Eve to be exact) but it was just the white plastic thingy that goes over the pedal that broke. I managed to get the car towed back home and got a replacement cable from Peugeot in Nambour. Now, I've followed some instructions I found on the net describing how to remove this cable and all has gone good so far until now - how the hell do you get the cable grommet out from the bulkhead with those two pipes running right across the top of the grommet ? Any help on this would be gratefully received or does anyone on he know a good Peugeot mobile mechanic on the Sunshine Coast?
    Apr 2005
    866
    I assume it is aircond piping that is the issue. This post, and the following one 306 S16 gearbox removal are what I did. I can't remember the exact details but I think there were a few nuts I had to remove either end of the aircond piping to allow me to maneuver it (gently) out of the way.
    Tony.
    306 S16 1995 black
    Don't remind me!
    16,609
    Quote Originally Posted by jc_hoops
    ...does anyone on he know a good Peugeot mobile mechanic on the Sunshine Coast?
    Tried asking the Mongols MC? One member has extensive Pug experience.
    Aside from that option, are you sure the grommet doesn't go back into the car?
    Jun 2011
    50
    I've had a bit of a think, and I might as well get the 306 back on the road if I can get it done for not too much (say, under $1000), and then drive it around for a while, with the intention of getting rid of it mid-year. At least then it buys me a little more time to save up and shop around for a replacement.
    Don't remind me!
    16,609
    You don't get a car without money needing to be spent on it (sooner than later) for less than $1500 plus on road costs. In that context it can be sensible to fix the existing.
    I would suggest it's the right time to install a like for like second hand motor. You're more than halfway there doing the clutch bearing.
    Jun 2011
    50
    I'd expected that a new engine/gearbox would cost more than the car's worth to do. I'd be looking at around $5000 on a replacement car if I go that route.
    Apr 2005
    866
    It's a difficult call. In some respects its a case of better the devil you know. But where do you stop. An exchange reco motor, new clutch and existing gearbox may be all that you need. Which model 306 is this? If its an XR or XT the power isn't that high so I would guess it would be less likely to be getting close to the exploding diff stage The BE3 box itself is unlikely to need any major work.
    BUT if you do spend the money I'd be looking it as a longer term option, not to sell in six months. Very unlikely you will recoup the money spent if you decide to sell it in the short term. The second hand value of 306's is next to nothing. Redbook has 2001 model 306 XT at between $2600 and $4100 for private sale and between $700 and $2200 for trade-in.
    Tony.
    306 S16 1995 black
    10,945
    Tony.
    That sums it up perfectly I'd say. Even for $5000 you may be buying someone else's trouble. And you have to go to the trouble of finding that $5000 car and verifying its condition to the extent practicable. If you can decide first exactly what model to buy and look at several, walking away from all but one of them, you can do fairly well for $5000 but you do need either that time and systematic approach or a good deal of luck.
    Renault 4CV 1951
    Renault R8 1965
    Jun 2011
    50
    True, but would I even get change from $4000 for an engine swap? After all, I don't have the tools, the space or the skills to do a DIY engine swap, the whole thing would be done by a mechanic.
    There's other stuff that'd to be sorted on the car too.
    Oh, it's an XSI.
    Apr 2005
    866
    OK and XSI, that changes things somewhat. What year model?
    I'd definitely be more inclined to do something with and XSI than an XT or XR, but it is also going to be harder to find an engine. I think the best thing to do is talk to a mechanic you trust, and get an estimate of what it would cost you for a rebuild of your own engine. Are you even sure it is burning the oil and not leaking it? Get a compression test done to evaluate the state.
    I'm guessing it's not an XU10j4 (I think the later XSI's came with them) as if it were I'd be surprised if it is knackered by 210,000KM.
    But yes, engine swap/rebuild is likely to be expensive, and still no guarantee's you won't run into other problems. Bit of a damned if you do, damned if you don't scenario You could perhaps buy a $1000 corolla and sell it again when you have your situation sorted, that would buy some time
    Tony.
    306 S16 1995 black
    Don't remind me!
    16,609
    Shopping around should turn up a 2 litre engine with 200K-ish km for below $500 on a "you come and get it" basis. A gearbox $300-$500 in good order; scrape up a used clutch with plenty of meat on the disc and lightly resurface your flywheel. Only new bits would be the input shaft bearing/seal, fork pivot bushes, thrust bearing and cable. Two successive weekends with a couple of half clued in people, decent tools and a crane - you're there.
