504 Number plate panel
    Jul 2003
    35
    Icon5 504 Number plate panel
    G'day Folks.
    Anyone know from experience how The recessed Panel which the rear number plate rivets to (between tail lights) on the 504 can be removed?
    Their doesn't appear to be any spot welds. It looks to be glued in and located by the mount for the boot latch.
    Any clues? What solvents or release agents get the part off? Apart from the angle grinder and hammer!
    1000+ Posts Shobbz's Avatar
    Brisbane, Australia
    1,284
    Isn't it a whole back body panel?
    Why do u want to remove it? Rust?
    shobbz
    Previous
    2005 407 ST Exec
    1975 504 GL
    12,266
    Quote Originally Posted by Shobbz
    shobbz
    i thought they were spot welded in
    they do rust around where the chrome strip is around the edge of the recess
    without going down into the backyard with a torch and having a look at one down there i can't help you much more at the moment
    but i thought they were spot welded in
    they aren't part of the rear panel
    1 x 2018 3008
    1 x 2000 Citroen XM,
    1 x '98 306 GTi6 sadly sold
    9,223
    We've had a look... it must be spot-welded. Has to be...
    So if you scrape around the inside of the panel, on the lip where it's joined, you should find signs of the spot welding.
    Drill through them and you should get it off fine...
