85 505 s rear end noise
    6
    Default 85 505 s rear end noise
    Mates,
    I am encountering rear end noise much like that of a draging brake rotor at speeds under 30km at higher speeds it stops any ideas?
    nJm
    nJm is offline
    Guru nJm's Avatar
    Jan 2002
    Melbourne, Australia
    2,930
    Have a search through this forum on the well documented problem of 505's getting their rear calipers locked on after using the hand brake.
    Nick
    1983 Peugeot 505 GR
    6
    Default that was it
    the rear calipers where locked tight as a winch on the rotors have to turn the rotors and new brakes thanks for the insight
    9,223
    Is it in the common faults forum, Nick?
    If so, go to that forum and do a search there... just put in 'brake' or 'lock*' and you'll soon find it.
