205 Weber conversion question
Results 1 to 15 of 15
    Fellow Frogger! Edd205's Avatar
    Feb 2013
    Aldinga
    124
    Default 205 Weber conversion question
    Hi all,
    am currently converting my 205 to twin Weber DCOE 45 and have struck an issue. The alternator is in the way of the new manifold and I can't lower it any further as it hits the power steering pump.
    My options seem to be find a bracket to lower the whole lot, which I can't seem to find, or remove the power steering to make room to lower the alternator.
    As this is a competition car I'm not fussed about losing the power steer, just want to know if anyone has encountered this and could offer some advice.
    Thanks.
    7,481
    Sort of related but a different problem. What are you using for ignition?
    Feb 2013
    Aldinga
    124
    Just a normal coil, planning to upgrade it at some stage but haven't yet.
    7,481
    Yes, but what will fire the coil? How will the advance curve be determined?
    Feb 2013
    Aldinga
    124
    I don't know, whatever did it before. The car was already carb so I'm simply replacing the single carb with two and have found the alternator in the way.
    1000+ Posts djvu205's Avatar
    1,402
    Quote Originally Posted by Edd205 View Post
    does it have air cond? if so you will need to ditch it and try using a non air cond alt bracket?
    Feb 2013
    Aldinga
    124
    It did have but I've ditched it. Is the bracket from a non a.c. car different?
    Via the aussiefrogs App
    Fellow Frogger! lozenge's Avatar
    Castlemaine
    493
    in my early days on this forum, 2007 with my newly backontheroad GTi, I remember
    somewhere here advertizing an Si, Blue Mountains maybe, with various GTi bits and a downdraught Weber,
    is that your car Edd? it sounded good. good luck with the DCOEs.
    8,996
    You would probably need the alternator bracket off a non PS car (and ditch the PS).
    This might be a problem though because I have noticed quite a difference in steering weight between my PS Si (engine off) and non PS GTI which makes me think the rack is quicker on PS cars.
    ACHTUNG ALLES LOOKENPEEPERS
    9,258
    Yes, of course, 2.75 turns for the Si.
    The suggestion made to me by Adrian was to use an Astra electric PS pump.
    I have for the moment decided to use the ITBs with a 16 valve, but would use the Astra pump if I put them on my 8 valve engine.
    Graham
    You would probably need the alternator bracket off a non PS car (and ditch the PS). This might be a problem though because I have noticed quite a difference in steering weight between my PS Si (engine off) and non PS GTI which makes me think the rack is quicker on PS cars.
    Feb 2013
    Aldinga
    124
    Quote Originally Posted by lozenge View Post
    I bought it from a guy in the Adelaide hills at the beginning of this year, went hard even with the DGV, so can't wait to get the DCOEs running.
    Feb 2013
    Aldinga
    124
    Graham
    Which year Astra would this be from? What is involved in the install?
    1,402
    it may be the power steering that gets in the way i cant remember either way im pretty sure that there are two types of alternator brakets. sorry to give you a bump steer i think im getting my ac and ps mixed up ive been living in the world of datsuns.
    1000+ Posts pgti6's Avatar
    May 2001
    1,618
    I fitted EHPS from a '94 TS Astra into my 405. It's a pretty straight forward job. I'm sure there's room in a 205 engine bay to do the same.
    Attached Thumbnails Attached Thumbnails 205 Weber conversion question-astra_ehps.jpg
    Lap times-
    Sandown 1 27.9
    Phillip Island 1 53.8
    Previous Frenchies-
    1988 205Gti
    1998 306 GTi6
    1997 306 N5 sedan
    1996 306 N3 XT hatch
    Feb 2013
    Aldinga
    124
    OK well this is definitely worth some consideration but this kind of thing is new to me. Could anyone run me through the basic points of the install?
